Iray animation it stops
WendyLuvsCatzWendyLuvsCatz Posts: 40,518
edited November 2015 in Daz Studio Discussion
it goes smoothly 30 secs a frame ( I limited samples and time) then just stops, I have no idea why
has happened twice now on DS4.9 beta
I cancelled and attached logfile
repeats this
Iray INFO - module:category(IRAY:RENDER):   1.4   IRAY
rend info : CUDA device 0 (GeForce GTX 980 Ti): Prevented
device timeout
  • RuphussRuphuss Posts: 2,631
    it says gpu load 99%
    memory used 2298
    your card has 6 GB ?
    somethings wrong here
    the GTX 760 you are also using
    can it behave as a bottleneck ?
    what is shown on the first side of gpu-z as memory size ?
    Post edited by Ruphuss on
  • Well I disabled the 760 in Iray
    it is only used in Octane in DS4.7 as I will not pay to upgrade the plugin
    I sometimes use it in Carrara octane if load below 2GB as easier to do on the fly for extra cuda cores but on GPU-Z in iray it is zero
    as I said it renders fine until 48 frames
    I am now redoing my render with. HDRI no cyclorama mesh or grass and its still going at frame 87 as I post
  • This seems to be since upgrading to 4.9
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,518
    It stops now at 88 frames after applying iray uber shader to all surfaces
    just the fox with rigged fur renders all 800 frames
    and it fits on my 760 in DS4.7 Octane render 1.2 so not a size issue card wise
    the fact it renders frames before stopping to me suggests DS 4.9 is accumulating data somewhere as it goes a memory leak
    the last image is DS4.7 Octane frame 90 and still going fine
    1920 x 1080 - 971K
    1920 x 1080 - 885K
    1920 x 1080 - 970K
    1920 x 1080 - 1014K
  • what I have, first two iray stopped next no props finished last full scene in Octane render on 760 as cannot use 980ti with 1.2
  • I really want to solve this as wish to animate using iray and it happens quite often lately not just this scene
  • I have discovered something
    my files are gone, my rigged fibrehair fox fur support asset is gone, my scene and scene subsets load as cubes
    I rigged stuff before too in DS4.9 and suspect those gone too, is the common factor, I have no database as using valentina and older Carrara so the new system prob hates me
    Stuff saved from DS4.7 is fine
    which is why I shall keeep using it for content creation not the beta
