SE PT Modern Apartment Poses for Genesis 9
Angel_X
in The Commons
https://www.daz3d.com/se-pt-modern-apartment-poses-for-genesis-9
Are these hierarchical poses?...
If anyone who has purchased them could let me know.
I already have many household items (plates, mugs, etc.) and I'm not interested in the ones required for the poses.
Thanks to anyone who can answer. :)
Just checked them out and no, they are not hierarchical poses. They do pose in place in the apartment and there is a folder of smart props included but I think you need the original props for these to work. I can't test if that is the case as I have all the props already.
I have this set, but not the location or all of the props, and from experience you can load the pose and insert your own (spoon, cup, bouquet of flowers, whatever).
Attaching a render showing the last pose of the set with neither the location nor the prop suggested. (Not the greatest render; I need to redo it now that I have some better tools and knowledge, but it gets the point accross.)
Thank you! Glad you enjoyed. :)
Thanks @Lorraine and @SilverGirl (beatifull render) I buy them at OS.
P.S.: I had problems with "Rogue Rider Poses for Dark Classic Motorcycle and Genesis 9" when I tried to use the poses and they didn't work, the description doesn't say "hierarchical". :(
That one's weird. Target the motorcylce to apply the pose (instead of targeting G9). It'll work like that.
ETA: The description/title is accurate. The poses are for the motorcycle with G9, not G9 with the motorcycle. It's just that no other set I know of works like that, so it's not the assumption you make right off the bat.
A few years ago, hierarchical poses weren't used.
There were character poses and prop poses.
I bought those poses so I could use them with other motorcycles (that I own) with some adjustments...
... anyway, I'm lucky I also have that motorcycle, and I'll save the G9 poses in separate files.
Thanks for your answers.
P.S.: I'm Italian, so I apologize if I can't explain properly. I learned English at school, so it's difficult to understand everything clearly. I'm using Google Translater, hoping it can help. :)
Hey, your English is way better than my Italian! I understood you just fine. :)
You are very welcome :)
