Adding to Cart…
Very fun shader set
It defs takes me a bit of fiddling to get what I imagine to come through with the different settings, but I'm slowly figuring out. This was the default from memory.
@sid great image! It's showing as huge in your post so you may want to edit your post and resize the embedded version to a max width of 800, before Richard has to edit it.
It was really tricky figuring out the best approach to preset icons/tooltip icons because the power of this product really comes from mixing and matching different presets together. As such I decided to create all the icons with default settings, with the exception of presets for a specfic setting.
Also, the result you get is highly dependent on UV's of the item it is applied to, if not strand-based hair of course, so it's actually impossible to show a true like for like preview as with standard shaders.
EDIT: I should add that I did add a help dialog script to explain things in more detail, as I do appreciate this shader is quite complex - you can find that in the root product directory.
