MATS gone white, cannot be replaced
mcorrmcorr Posts: 1,105
I have a weird problem. I did i do not know what, and at some I realized that the texture mats on my character went white. Undoing did not restore them to the original. I saved a previous version's mats as a material set, but am not able to apply that either: still white. Even weirder: the surfaces tabs all have the Mats loaded. And applying a different character's Mats does nothing either: still white. Anybody encountered this before? And how to resolve this?
  • backgroundbackground Posts: 942
    Is it possible you have the viewport in smooth shaded mode?
  • lilweeplilweep Posts: 2,879
    Do you have a geoshell on the character? or did you try to apply a geoshell material to your character? Sometimes such changes cannot be Ctrl+Z'd for some reason.
  • CybersoxCybersox Posts: 10,025
    Yeah, sounds like a geoshell/geograft issue.  It's especially easy to run into this problem with G9 as it's much more dependent upon grafts and geoshells than previous generations were.  Easiest way to check would be to pull up a base version of the figure and then apply your saved texture to that to see if it shows on the unmodified base.
  • Richard HaseltineRichard Haseltine Posts: 111,875
    Is it the whole scene or just parts?
  • SilverGirlSilverGirl Posts: 3,988
    I have this issue with one of my chracters who uses the MB Sarice textures for her skin. And it's not even necessarily a geoshell issue... sometimes the mats just go poof for no apparent reason whatsoever.
    Sometimes, for reasons beyond my ken, when reapplying the mats won't work... loading in Sarice as a new character (textures and everything applied) and THEN applying the mats to the desired character makes them take.
    Go figure, right? But give it a try, maybe it'll work for you.
    Good luck.
  • Silas3DSilas3D Posts: 836
    I often see this issue when undoing something, usually when applying a different shader eg going from pbrskin to iray uber. For some reason effected properties become unmappable, hence the texture providing color disappears. When this happens I find i have to restart DS, because reapplying a material or the base shader doesn't bring the image inputs back.
