do you think the same face morph dimensions for V4 would work for V7?
I have the face morph dimensions for a V4 figure and was thinking I could go more modern and convert over to V7 and was wondering if the same face morph dimensions for V4 would morph the same face with V7? does it work like this?
  • I'm not sure what you mean - parameter settings? If so then not really as the morphs are not the same - there aren't the same morphs available, and they are making a different change to a different figure even where similarly named moprhs exist on both. You might want to look at GenX 2 in the store.
  • ValandarValandar Posts: 1,418
    To put it simply, a morph is a list of directions and distances to move the vertices that make up the figure. If it's a different figure, it has different vertices, and therefore cannot use that morph.
