Genies for G8M/F [commercial]
2»
  • nemesis10nemesis10 Posts: 3,908
    edited October 2021
    May I add that this is also a lovely head sculpt?
    1488 x 1261 - 433K
    Post edited by nemesis10 on
  • RawArtRawArt Posts: 6,147
    Thanx...lovely render :)
  • Wishlisted for now, will get as soon as I can afford it. :) Dunno if anyone here is into Kamen Rider, but the smoke tail would be perfect for 'inner demons' like Vice from the current Kamen Rider series.
    484 x 677 - 190K
  • GranvilleGranville Posts: 700
    Thanks RawArt! A definite buy.
  • RedfernRedfern Posts: 1,647
    Without the glittering, glowing and/or smoky effects added, does the "tail" blend with the skin tones of the torso, suggesting a worm-like extended appendage?
    with the default skins that come with it..yes it does
    Thanks for the prompt feedback.
  • Is there any way this could be attached to a G9 figure? (I doubt it.) Or are there plans for a G9 version?
    I will likely make some kind of G9 version....but since the set was not that popular for g8, its not on my "urgent" list....unless i come up with a really cool idea to make it worthwhile
  • NorthOf45NorthOf45 Posts: 5,765
    Something with volumetrics, perhaps. I should try AM's Mesh to Volume to see how it works on the existing genies...
    I was hoping to work with volumetrics but afaik there is no way to rig them and a static propis just not functional enough
    edited February 18
    Really cool
  • AdelaAdela Posts: 123
    PixelSploiting said:
     All I'm going to say I'm always in need of more Middle-Eastern or Indian looking characters and those figures are gorgeous even if may never use any djinni parts with them.
    Absolutely, I remember when Djins, Lizardian and Bapho were released around the same time,  that was such a great moment. They had so much personality, and you could really see the care and creativity behind their designs.
    I think many of us feel some kind of nostalgia, I would genuinely love to see them come back, whether as reissues, updated versions, or even new evolutions.
    Well, I got curious about using Mesh-to-Volume. Obviously it must be applied after posing, but results are promising, if somewhat crude. It is kind of chunky, but while making the voxels smaller (<0.5) makes smoother volumes, it clips the bounds prematurely, well inside the geometry, when the tail is posed. Same for very large voxel sizes, the volume actually is created outside the geometry. Contained Volume or Expanding Volume doesn't seem to make a difference.
    If you want to try, hide everything (including all shells) except the tail to run the utility. (there might be other configurations that work also)
    Vertical blend 1.0
    Intensity and Frequency: middling values.
    Adjust the Density Multiplier on the surfaces tab to actually see something after generating the volume.
    Make everything visible again. I only used Genie-Shell-1, leaving 2 and 3 off.
    800 x 757 - 86K
    It is great to see the interest in these guys. I did enjoy making them.
    As soon as I come up with an idea how to make them new and better I will definately work on them....thanx for the motivation
  • ArtiniArtini Posts: 10,608
    Vertical blend 1.0
    Great results.
    Are you using https://www.daz3d.com/mesh-to-volume-and-back ?
    Vertical blend 1.0
    Great results.
    Yes, but I am not that familiar with the process. It seems straightforward enough, but did not always do what I expected. It's a starting point...
    I added the pair to my WL after this thread was revised.
    Sometimes it is easy to miss things when they come out
  • Hi RA,
    Just wondering, any plans to port/update this for G9 in the future?
    Still works great, but would be nice to see a new version some day :)
    As I said above...as soon as I get a new idea how to make them better, then I will try something
