Panel Layouts
Is there any way to setup the screen layout so that the panels are groups as shown? Basically, I want the RIGHT panel (purplish) to always be the full height of the window and have the BOTTOM panel only be beneath the LEFT and CENTER panels. I tried modifying layouts.dsx directly. But it didn't like nested PaneGroups.
EDIT: Ooops (And as soon as I forget the attachment, cloudflare acts up)
Post edited by jmucchiello on
AFAIK, what you want isn't possible.
The closest would be to put a pane group to the right of the time line group.
The drawback, the tab orientation would be on top and not the side.
Yes, the top and botom pane wells stretch the full width of the UI - they cut off the left, right, and centre wells
That's disappointing. I don't need two full width panes. I'd prefer more than one full height pane.
If you have enough screen resolution, you can get more than one full height pane.
