Panel Layouts
jmucchiellojmucchiello Posts: 2,531
Is there any way to setup the screen layout so that the panels are groups as shown? Basically, I want the RIGHT panel (purplish) to always be the full height of the window and have the BOTTOM panel only be beneath the LEFT and CENTER panels. I tried modifying layouts.dsx directly. But it didn't like nested PaneGroups.
EDIT: Ooops (And as soon as I forget the attachment, cloudflare acts up)
1147 x 663 - 298K
Post edited by jmucchiello on
  • AFAIK, what you want isn't possible.
    The closest would be to put a pane group to the right of the time line group.
    The drawback, the tab orientation would be on top and not the side.
  • Richard HaseltineRichard Haseltine Posts: 111,929
    Yes, the top and botom pane wells stretch the full width of the UI - they cut off the left, right, and centre wells
  • jmucchiellojmucchiello Posts: 2,531
    That's disappointing. I don't need two full width panes. I'd prefer more than one full height pane.
  • prixatprixat Posts: 1,629
    If you have enough screen resolution, you can get more than one full height pane.
    2776 x 1503 - 622K
