Cant find installer
Hello, I bought the space expansion kit that says it comes with a bryce installer but i cant find the installer, does anyone know where to find it?
  • Richard HaseltineRichard Haseltine Posts: 109,650
    edited March 29
    You may need to look in your product library https://www.daz3d.com/downloader/customer/files#prod_20157
  • Yeah i checked there but it wont show up, only the kit
    What dd you buy? That is the only product I could find with a similar name, and I assume that has a download link towards the bottom of the page (it's not a product in my library, so I can't check).
    If you want to post an image you need to atach t or host it on another site - pasting into the post itself doesn't show in the thread, as you can (not) see.
  • ohh i tried pasting the image into the post, sorry for them not appearing!
    Here, the product was space construction and it said it came with the installer for bryce buttt it wont show up for some reason
    348 x 342 - 12K
    Have you tried expanding the entries on the product page (clck the right-pointing triangle)? The product page lists instal methods, so there should be files associated with the product in the database. If not this is probably something that needs a Technical Support ticket https://helpdaz.zendesk.com/hc/en-us
  • MelanieLMelanieL Posts: 7,815
    edited March 30
    And when you click on the name at the left in your Product Library are you  not seeing the installer like this?
    1175 x 686 - 98K
    Post edited by MelanieL on
    edited March 30
    Oh hold on, were you expecting to get an installer for the Bryce application not just the kit? That's not what the store page means - it means that the Space Construction Kit comes with an installer for the kit to be used in Bryce (assuming you already own Bryce 7 Pro).
    For the actual application you need to buy Bryce 7 Pro - you can find it here - currently for 3.29 dollars (or less if you are a DAZ+/Premium member)
    1353 x 897 - 210K
  • ohhh alright, thanks for letting me know! i was confused for a bit lol
