How do I change lip color on Genesis 9 Ralynna?
Hello, I purchased this model. I was able to change her eye color but cannot figure out how to change her lip color due to there not being a separate lip option. When I click Makeup, it just makes whole face white. I dont want to change all of it, just her lips. Any suggestions are welcomed.
  • felisfelis Posts: 6,490
    edited March 21
    This? https://www.daz3d.com/noki-ralynna-hd-for-genesis-9
    Based on the product page and file list it doesn't look like she has more lip colors.
    So to change it; I would make a lip mask (black-white image) you can use in the Make-up channel (assuming she uses PBRSkin) as weight and then apply any color you like. You can set the make-up weight less than 100, e.g. 80-90.
    For making a mask use the UV layout for the head and paint the polygons representing the lips (or slightly less) white, and blut, with a black background.
    Attached is one I made some years ago (I made different sizes, can't remember which I preferred).
    4096 x 4096 - 335K
    Post edited by felis on
    You can also try applying lip color from another model in the same generation.  If the lip colors on the other models aren't a full face make up, it will apply to just the lips.  You can also buy seperate make up options that usually include lip colors but its easiest to use them from another model.
