Adding to Cart…
DS6 is a huge change in the scripting, especially because of how I designed my scripts. I definitely will let people know if a product supports DS2026 - all my upcoming products will.
You're welcome! I think this is a fantastic upgrade - it contains my wishlist of features for LAM
I wanted to show continuity with LAMII - I thought this was a playful way to modify LAMII's main promo.
Feature request noted.
I guess it does not work with instances.
I have tried to make instances to look at the elephant in the middle, but got only the error message.
I have to make my own script for such cases.
No, they do not work for instances, as far as for posing. Instances are just a node with no head or eyes.
An instance is an exact copy of the source object, so it's not surprising the script can't repose them.
You'd probably need to pose the original to look at the center elephant, then create instances with a radial distribution around the center elephant (there's a tool in Code66 Toolbox 3 which looks like it could help with that, if you have it)
Yes, I have purchased it. Need to explore it more.
Works nicely with 3D Universe animals.
Thanks for sharing @Artini!
