My Discovery - of interest to Filament / Cartoon shaders
Drogo NazhurDrogo Nazhur Posts: 1,292
edited March 9 in The Commons
As I'm sure most already know, Genesis 9 introduced us to a new Filament shader option which gives a cartoon'ish look to the renders and is an improvement over the existing "Cartoon" render option. I've been using this a lot for objects in the background of my scenes -- magazine covers, a television screen, etc. I'm also going to be doing some illustrated stories of a story within a story.
But I'm sure nobody cares about any of that. However, what you might be interested in is something that I did by accident. I overlayed an IRAY render with the old cartoon render and I really like how it came out. I like it even better that the new Filament render.
I just wanted to share my discovery in case others also like it and want to have the same "look" to their cartoon renders.
Post edited by Drogo Nazhur on
  • MimicMollyMimicMolly Posts: 2,339
    edited March 9
    For Filament, I like the Filatoon outline on top of the figure, except not black, with the Iray mats underneath. To me, the Filament renders really need the outline, so they wouldn't look as washed out. Then, I also throw in the Genesis 9 Tear, and dye that sort of dark pink to match the skin. Rotation of the dome also affects the lighting, so I play around with that. This example is of the anime/toon figure, except I dialed it out and replaced the shape with a realistic one, like Maya for Genesis 9
    I don't like the Cartoon Shaded much. But if I do use it, I always make the scleras invisible so they won't have the "white eyes."
    816 x 1450 - 1M
    Post edited by MimicMolly on
  • Drogo NazhurDrogo Nazhur Posts: 1,292
    Thank you for the recommedation.
  • 3Diva3Diva Posts: 12,014
    edited March 10
    That's a cool discovery!
    Have you tried the Filatoon shaders that come with Daz Studio? They can give very cool NPR looks without the extra work of rendering two different images and then layering them in an image editor. :)
    2000 x 2600 - 2M
    2000 x 2600 - 2M
    Post edited by 3Diva on
  • wsterdanwsterdan Posts: 3,161
    3Diva is too modest to recommend her own product, but if you're enjoying tinkering with Filatoon you owe it to yourself to take a look at:
    https://www.daz3d.com/easy-filatoon
    It allows you to test dozens dozens of different Filatoon settings for materials, lights, environments, outlines and more. It's amazing how many tests you can do so incredibly rapidly. I highly recommend it.
  • takezo_3001takezo_3001 Posts: 2,037
    Seconded, definitely seconded, it is indeed an excellent tool, and the cherry on top, is that it works flawlessly with the 2026 beta!
  • vrba79vrba79 Posts: 1,548
    Filatoon is almost as versatile as the old PwToon shader for 3DL was, but it inherits all of the limitations that are native to Filament itself. After using Filatoon for about a year and a half I ended up migrating back to using Sketchy Toon for Iray.
  • jmucchiellojmucchiello Posts: 865
    My issue with Filatoon is the lack of recent support both by PAs (forgivable since no one is clamouring for the stuff) and Daz Originals. Every time I see a new DO bundle... no filatoon option. Maybe a cool environment drops? No filatoon option. Clothing? Nope. Pose pack? No.
    I think the "WOW" factor has worn of for most of the PAs. I would have loved to seen at least a LIE preset that added Borderlands or Telltale Games style ink marks to the characters, but thems the breaks.
    What is this "Sketchy Toon" of which you speak?
    This looks VERY impressive. How simple or complicated is it to use? Will it work on earlier Genesis's?
    It's super easy to use and there are universal presets you can apply to any figure. In fact older Genesis figures look pretty great all Filatooned up!
    edited March 13
    Sketchy Toon for Iray. Bit of a learning curve, but it can produce nice results. https://www.daz3d.com/sketchy-toon-edge-and-art-style-shaders-for-iray
    Post edited by vrba79 on
  • LeanaLeana Posts: 12,937
    If you're interested in Filatoon, there are two big threads where you can find tips as well as examples of it used on various figures and sets:
    https://www.daz3d.com/forums/discussion/704951/anime-toons-and-filatoon-shader-q-a/p1 (first post has lots of info about the shader itself)
    https://www.daz3d.com/forums/discussion/704931/filatoon-cell-shaded-rendering-with-filament/p1
    I'll add to that the commercial thread on Easy Filatoon, lots of different figures and effects shown:
    https://www.daz3d.com/forums/discussion/723761/easy-filatoon-commercial#latest
    It works great with any older assets. It's recommended that 3DL be converted to Iray first. I use https://www.daz3d.com/rssy-3delight-to-iray-converter as it's is a script, is fast and the devs include a clear manual.
  • HavosHavos Posts: 5,622
    I am curious, why would a pose pack need a filatoon option? (or indeed any renderer option).
