New PC Specs
omvendtomvendt Posts: 112
I am thinking of getting a new PC with a RTX 50xx card. I know that that GPU doesn't work w the current version of Daz, but soon they probably will. My question is, should I prefer Intel CPUs over AMD CPUs?
Thanks in advance
(O:
  • LeanaLeana Posts: 12,936
    edited March 12
    Just to be clear: 50xx cards are not expected to be supported in DS4 for Iray rendering in the future. The versions of Iray which support those cards can't be integrated in DS4 code base due to technical limitations, and that most likely won't change.
    The only version they are compatible with is DS2026 (which is technically DS6), which is currently in beta.
    Post edited by Leana on
  • omvendtomvendt Posts: 112
    Great, thanks, so I should get dual RTX4090 cards instead, I suppose
  • ChezjuanChezjuan Posts: 542
    Other than Daz Studio, what do you plan on using the PC for? That will help answer the CPU question.
