GENESIS 9 SUDDENLY CORRUPTED
CykloneCyklone Posts: 163
Hi everybody,
The is a MAYDAY message : all what OK two days ago and for no apparent reasons today genesis 9 iscompletly corrupted, meaniong that any of th echaracters that I have bought in the pas are not usable anymore.
Here's how Genesis 9 looks kie when I load it (see attached - I absolutly done nothing on it)
I've already done the full check to see if any cursor would be enable and creating this isssue : NADA !
All the work that I've done is going to trash....
Any help you be much appreciated !
Cheers !
  • GhostofMacbethGhostofMacbeth Posts: 1,759
    Click on the parameters tab and then click on "currently used." You should see a recently installed character that is not zeroed. Easiest way to fix it is to uninstall that character. You can then submit a ticket that it is not zeroed and needs to be updated.
  • Matt_CastleMatt_Castle Posts: 3,085
    edited March 13
    Based on this other thread, it seems that the Premier character associated with Sigrid defaults to on: https://www.daz3d.com/forums/discussion/757596/i-m-having-the-breast-day-ever
    As a premier character with encrypted files, you cannot update her files yourself, so your only option to get her fixed is to uninstall her and put in a ticket.
    Post edited by Matt_Castle on
