What is causing this how do I fix it?
leo04
This is a M4 conversion to a G3 model, using the GenX addon. (GenX2 and GenX3) I also used the Legacy UVs for Genesis 3: Michael 4 to map the skin.
I saved a material preset of the M4 model skin, mapped tothe M4 model, to have a map to apply during the process.
I followed the Manual to add the GeoCrafts fot the UV stuff and got the result i wanted, but after saving and re-opening the model, I am getting the GeoCraft stuff bleeding through.See image.
I would happily use another skin for a G3 model but I really need the face for the character.
Any help on how to fix this would be appreicated.
Thanks.
Post edited by leo04 on
That doesn't seem to be an UV issue.... but have you dbl-check the UV Sets on the surfaces of geo-graft in Surfaces pane ? And any geo-shell on the figure ?
Checked for what? I was able to get it to work the first time but when I opened the model again it looked like the image.
When that sort of thing happens to me it usually indicates that a texture map which was used in the original scene was not saved, so it can't be applied when you load the character again. Possibly it was overwritten with a different texture with the same name, otherwise Studio will put up a dialog box asking you to locate the missing texture.
Does the re-opened model include the geografts? And if so, have the UVs of the geografts been set to "Michael 4"?
EDIT: If you saved the figure as a Character preset it will not include the geografts. However if you save it as a Persona preset it appears it will include the geografts, complete with all material settings.
I think I figured it out. I had the Meshgrabber function clicked on. I have had this issue before but forgot about it causing an issue.
Thanks
