Fluidos II upgrade from Lite won't install
omvendtomvendt Posts: 223
Dear experts,
Do any of you have experience with Fluidos II?
I bought the upgrade from the Lite edition. Fluidos II Lite installed fine, I think. Haven't actually tried it yet. But the Upgrade to the full package is stuck in the Daz Install Manager. See picture. I turned the computer off and back on and still the same.
Any ideas?
Thanks in advance!
(O:
  • felisfelis Posts: 6,604
    Have you tried with some hours apart?
    It might be a temporary server issue.
    As felis said, sometimes you have to wait a little while - probably for some caching server to get updated. Under the cog icon (top right of the DIM window) is a link to the log - click that and scroll down to the bottom and it should give a hint as to the error.
    If waiting a few hours doesn't work then try going to the product page within your library and download the DIM zips manually. If that works then you can copy them to your DIM downloads folder, hit refresh in DIM and they should popup as available to install.
  • ElorElor Posts: 4,232
    I had the same problem and I tried a couple of days away back then without success.
    The files are also not available on Daz3D.com.
