EZFinder - Advanced Content Manager for Daz Studio [Commercial]
245678
  • ArtiniArtini Posts: 10,951
    Ok, thanks.
  • RandomRandom Posts: 254
    Not so. I don't use smart content and EZ Finder works fine.
    edited February 25
    Another suggestion. The left hand column that lists the separate categories/folders that EZF has gone through. The separation between the 'main' content and the 'imported' content can't be adjusted. Would be nice if you're like me and have 99.9% imported so I don't have to scroll to get to click on where I want.
    BTW, search is wonderful. Sooo much faster than the search feature in Studio.Practically instaneaous.
    Post edited by Random on
    Smart Content is often used as a synonym for the Content Management System and metdadata, but it isn't. In this case I think it is using the metadata from the database, which will be added when you install content from Daz and some third-party content, regradless of how you access the content inside DS.
  • XelloszXellosz Posts: 855
    I could get the EZHDRI working on a 10k+ product external drive; the scan took 1/2-1hours.
    problems: - Things that are not HDRI-s are listed. Probably it's on DAZ, since it was imported due to bad metadata.
    I didn't have more time to test other things. Can HDRI-s be sorted into folders?
  • EZ3DTVEZ3DTV Posts: 1,663
    edited February 25
    From my understanding this does not make sense: “it was imported due to bad metadata” Are you saying you think your external drive the files are corrupted? EZHDRI should only return with .hdr and .exr file search results it does not concern itself with any other file type (although EZHDRI does create DUF, HTML and PNG files this is how it links to your data). EZHDRI does not actually copy your HDRI files it just makes pointer files and thumbnails to the data. I need more information. One solution is to use Windows File Manager and do a global search through your external drive for *.hdr and *.exr and “copy” (not move) the results from the two searches to a folder, then run EZHDRI on that folder. Then EZFinder can help you organize your HDRIs and allow you to use the two click system to insert them into Daz Studio. This approach will work if the external drive is functioning properly. The HDRI results should appear here:
      When the HDRI scan appears there, double click the scan folder to insert its contents into the thumbnail grid in the main workspace.
    861 x 1792 - 279K
    Post edited by EZ3DTV on
    I am glad the search is helpful to you!  yes
  • Charlie JudgeCharlie Judge Posts: 13,651
    ArtAngel said:
    Firstly I do not personally know this PA nor have I ever had contact with him, simply an observer. This PA is social and he does not edit his videos. What you see is what you get, no fluff. No short cuts. He makes time for everyone and is extremely interactive with his live feed, which can result in long videos but he does address all concerns and viewer queries. I think this product is brilliant. In DIM downloads for DAZ my purchases exceed 4 TB. It will scan large projects and large duf scenes. The PA did not only utilixa the PA meta data, added additional meta data to the existing meta data. It will find all 3Delight shaders and auto populate them as IRAY which comes in handy with 4.24+. It does not make any changes to your DAZ library. If you delete items from EZFinder it will not affect your installed library. You can tell it where your library is and that can be any drive C D f J K L. When you search environments in Smart content you know you have more scenes, more shaders than the thousand or two DAZ populates and this finds all those gems be it 20,000 or 50,000. This is a crazy good product. It took me years to organize my manual downloads because Smart Content sucked. Now it doesn't
    I suggest everyone watch this:
    Very helpful video. Thanks
    Thanks for watching Charlie Judge! yes
    edited February 26
    Will you be making another one that covers using EZShader in detail ?
    Post edited by Charlie Judge on
    Hello Charlie! I will try and make a live video tonight on EZShader if I feel up to it. smiley
  • ArtAngelArtAngel Posts: 2,096
    edited February 26
    It's up!
    If you are feeling comfy with program just skip to 58.23 . . . Because I am still learning I am watching it all. It's currently live so you can shoot questions at the PA.
    Post edited by ArtAngel on
    ArtAngel said:
    It's up!
    Kind thanks to you ArtAngel for sharing my vid! angel
    Great. I am only installing the content via DIM, so hopefully it will work. Right?
    EZFinder works best when your DAZ library follows the standard folder structure, People, Environments, Runtime, and so on. The compartment scanner uses these folder names to automatically classify your content into the right categories. If any of these folders have been renamed, EZFinder will still find all of your files, but they'll fall into generic categories like 'Other' instead of being sorted precisely. The scanner always has a fallback, nothing gets lost, but you may end up doing more manual organization to get things where you want them.
    EZ3DTV said:
    ArtAngel said:
    It's up!
    Thanks for making this. I will watch later today when I have more time available.
  • Thank you so much for this tool! I can see that after I spend the time setting everything up, this is going to save me SO MUCH TIME!
    That said, I do have some dream wishlist additions for the program that I think would make life even easier
    Sort options
    • Alphabetical (by package) sort option
    Filtration/Search
    • The ability to filter by whether an item has been categorized into the tabs yet or not (<-- This would be a GODSEND)
      OR
    • The ability to filter by a specific installation date range (like we can do in DIM to see, for example, things installed in the last week)
    (Anybody that's looking to filter by badge type, click Search Matrix and select your badge, then make sure the word check boxes are blank and do a search with no words in the bar)
    An Uncheck All button on the leftomost panel so I don't accidentally append a category I dont want to be working with (like, say having the first 10 pages of G9 hair being G8M characters because I didn't uncheck it when I thought I did, ope!) HAHA, I just found it! Left click and select "Unselect All Compartments"
  • tomekamansontomekamanson Posts: 24
    edited February 26
    Hi, thanks for making EZFinder. I've done a little with it. I think it will make finding the genre things I'm currently working with much easier. One, issue, I have found at least 1 asset that was not included in the scan. I'm organizing all my SciFi building stuff and noticed that StoneMason's Greeble City Blocks 2 did not scan.
    What is the easiest or best way to rescan or scan for missing items?
    Nevermind! I used EZReader button and searched for Greeble and found it. It wasn't showing up because it's a .daz file and not a .duf.
    Thanks for making this!
    Post edited by tomekamanson on
    edited February 27
    Thanks for the nice compliment tomekamanson! For hard to find items check all of the red checkboxes. Also, make sure you always click the "Clear UI" button before searching compartments. If there are any items in the workspace grid, search will search them "instead" of the compartments. Enjoy and have fun!
    3809 x 2048 - 350K
    3812 x 2050 - 420K
    Sort options
    Filtration/Search
      OR
    Alphabetize, I wish I had thought of that for sorting the workspace grid. It would make things easier. Read about "truth symbols" in the user's manual, they may be what you are thinking about for your categorization; and you also have custom color as a category marker. Unfortunately, tabs do not have color, only panels and folders/symbols.
    As for sorting, the program at one point did have sort by install date but I felt it was not that useful. The reason why was because my library once got corrupted, I had to reinstall and now, nearly all of my files have the same install date. So, I removed it (this was evidently a mistake). What I tried hard to get to work was “purchase date” But after many attempts to include this data, I don’t think Daz exposes that information, other than in your account area on the website and deep within Daz itself. Purchase date would be the ticket. SKU date seemed to be the compromise; it is pretty much a release date matrix. You can create virtual folders with dates on them but try and stay away from certain text symbols in virtual folder names, stick with numbers and letters.
    I hope EZFinder is helpful for your productivity and thanks for the nice comment XtraDimensional, and program suggestions are very much welcome! yessmiley
  • I am making very good use of the truth symbols!
    It's just a bit of a pain to go through and find newly-installed things to get them sorted correctly. (Thus why I say filtering by whether the items have truth symbols already would be a godsend!)
    MUCH less of a pain than trying to keep track of everything without this utility, though! Thank you so much for making it!
  • mindsongmindsong Posts: 1,788
    EZ3DTV said:
    Looking ahead, a future version of EZFinder may support running multiple instances simultaneously, each with its own user data profile and each pointing to a different library root. This would give users full multi-library coverage without compromising the portable relative path system — each instance remains a clean, self-contained world with its own scan data, compartments, and virtual folders. No architectural changes to the path system required.
    That would be a *great* feature addition, and presumably fairly simple, so long as the instance databases are isolated. That would be my only serious change request so far, and that's because of the multiple runtime library hacks I've been using for years to manage my data.
    One possible suggestion for a future version was similar to a previous suggestion, where the presentation of multiple screens of icons could be scrolled through with the mouse wheel... (or keyboard presses, as mentioned). Being able to roll through those screenfuls of thumbnails with the mouse roller would be pretty cool.
    Thanks for your work and support in here!
    cheers,
    --ms
  • kingyak42kingyak42 Posts: 25
    edited February 27
    Has anyone else run into a problem with folders randomly disappearing? Every time I restart the program, there are several folders that are just gone (always different ones). I've tried doing complete reset, and just now several folders disappearead as I was sorting without a shutdown or reload or anything.
    Post edited by kingyak42 on
    edited February 27
    I will look into it kingyak42, it may not be on your end. I have not experienced this, but it is not out of the question it could be happening.
    One workaround is saving your folders, panels, tabs and full layout often after you edit them a lot and then if they disappear reload them. I am working on an update and your issue will be addressed.
  • James_HJames_H Posts: 1,117
    A big limitation is the single Daz library: I have a  number in different places. Is there a solution?
      Great news! This has already been addressed! The v1.0.3 update was created tonight and I'll be uploading it to DAZ soon.
      They'll release it when they're ready.
      The update introduces library compartment tabs, you can scan each of your DAZ library locations as long as they're listed
      in your DAZ Install Manager. Scan as many locations as you want and organize them all together using virtual folders.
      Here's what else is new in v1.0.3:
      - Mouse wheel scrolling for page navigation
      - Sort by Install Date, Alphabetical, and Truth Symbol (unsorted items)
      - Fixed folder disappearing bugs (there were a few culprits)
      - Import External Scanner is now significantly faster
      - Various cosmetic fixes (text, button layout)
      The update installs right over your current version through DIM and your virtual folder work will remain intact. When the
      program launches after updating, just point it to your existing userdata folder when prompted.
    If anyone has feature requests, get them in now! smiley
  • Climberboy50Climberboy50 Posts: 15
    edited February 27
    @EZ3DTV -
    Would you be able to include some step-by-step screenshots in the manual?
    Post edited by Climberboy50 on
    May blessings rain upon you! Many, many thanks!
    Climberboy50 said:
    @EZ3DTV -
    I will edit the manual and add images, this could balloon the manual from 30 pages out to over 100 pages, it could also make EZFinder close to a GB install.
    I will try it and see how it works and if it is feasible.
    To update for new items for folders in external imports, are we stuck having to delete the whole folder and then reaquiring?
