Hairline issue on two hair items i recently bought
so recently i bought two hair items on a deal today dForce Raquel Hair for Genesis 3 & 8 Female(s) and dForce Ingrid Hair for Genesis 3 and 8 Female(s), so i'm aware of the head skull cap both these items came with but i'm having some difficulty with displaying them on the nvdia iray and setting the color scheme, the only way for them show is when i enable the Preview PR Hairs, but even so setting the colors is still difficult i click the color i want with the hair highlighted but most of them on nvdia iray shows them as sort of default and not the color i want i can show the images of what im talking about the first pic is what it looks like in texture mode the other is in iray mode
  • GordigGordig Posts: 10,785
    Most dForce hairs are set up not to display fully outside of full renders. If you select the hair itself (not the haircap) there's a setting in Parameters called Preview PR Hairs; set that to "On" if you want the hair to be fully visible in the preview window, but be advised that this is computationally heavy.
  • Puma283fPuma283f Posts: 52
    so thats the only way? what abour the colors i select the colors from the materials i use iray for said color but when i go to nvidia iray the color stays on default
  • felisfelis Posts: 6,490
    The hair is so old that it uses an older shader so you need to set Viewport Line Tesselation to 3, if you want to see it in viewport.
