Adding to Cart…
OK, so the "Edit Monkeys" got loose again, big time. Ignore the highlighted text then (Mertail NOT included?). And the Missing requirement, or is that just mats for the figure without any mats for the 'Mertail'?
The Mertail is not included in the Bundle or the Pack, those are just textures ,and well it does allow you to create a lovely underwater dweller .........just one with two legs and no tail ,unless you buy the set with the mertail ......and yes the Fantasy Pack is just textures for the Genesis3 female,NOT the LagunaMertail ......
Edit monkeys??? wow and here I thought it was gremlins!!
Understood, I'm just waiting on the Shopping cart plumbing to unclog itself from the place order flushing earlier this weekend.
Edit Monkeys, look good in a suit, make great pre-launch guinea pigs, and will work for banana peals. Just don't feed them after midnight, lol.
Hmm. Do the scales on the human portions of these sets overlay on the main skin, or are they their own skin that replaces the base?
IE: could I put this on top of Lynsey and have a darker skin with scales, or put it on Lady Rune and have tattoos plus scales?
The scales on the human portion are part of the Indigo skins and are their own skins not an scale overlay
Ok, thanks.
The scales that blend the top of the tail into the human skin are part of the tail and use transparency so they go over all skins.
Question does anybody have the same issue using gen3 and the Laguna tail in 4.21 in the iray view port the model is not more loading and stays grey if i move the view port its very badly lagging which was never a issue for me in the 4.12 version same for gen 8 mermaid tails the only one that works is the cora mermaid tail
Same problem in version 4.15. Worked fine in 4.11.
