I have issues with Laguna Mertail Set for Genesis3
13»
  • carrie58 said:
    All right, now I'm a tad confused? I picked up the "Laguna-FWSA Indigo and Jade Mermaid Fantasy Bundle",
    http://www.daz3d.com/laguna-fwsa-indigo-and-jade-mermaid-fantasy-bundle
    That containers the "Laguna-Mermaid Fantasy Pack for Genesis 3 Female(s)"
    http://www.daz3d.com/laguna-mermaid-fantasy-pack-for-genesis-3-female-s
    Tho there is also a "Laguna-Mermaid Set for Genesis 3 Female(s)", that is not in the Bundle?
    http://www.daz3d.com/laguna-mermaid-set-for-genesis-3-female-s
    What is what (Fantasy Pack vs Set), and what's the difference? Dose one require the other, and got missed it the details? Is one a 'Light' version of the other? (I'm just completely confused at this point)
    The Laguna-Mermaid Set for the Genesis 3 Female is the mertail and 2 different tops ,plus a couple of lovely textures ,the Fantasy pack contains textures for the Genesis 3 females,so does the fantasy Bundle ,but the bundle also contains regular human textures too.
    If you want more color variations for the tail you would need this : http://www.daz3d.com/laguna-colors-for-mermaid-set
    Hope this helps
    OK, so the "Edit Monkeys" got loose again, big time. Ignore the highlighted text then (Mertail NOT included?). And the Missing requirement, or is that just mats for the figure without any mats for the 'Mertail'?
    1034 x 966 - 132K
    1003 x 256 - 238K
  • carrie58carrie58 Posts: 4,171
    The Mertail is not included in the Bundle or the Pack, those are just textures ,and well it does allow you to create a lovely underwater dweller .........just one with two legs and no tail ,unless you buy the set with the mertail ......and yes the Fantasy Pack is just textures for the Genesis3 female,NOT the LagunaMertail ......
    Edit monkeys??? wow and here I thought it was gremlins!!
    Understood, I'm just waiting on the Shopping cart plumbing to unclog itself from the place order flushing earlier this weekend.
    Edit Monkeys, look good in a suit, make great pre-launch guinea pigs, and will work for banana peals. Just don't feed them after midnight, lol.
  • Hmm.  Do the scales on the human portions of these sets overlay on the main skin, or are they their own skin that replaces the base?
    IE: could I put this on top of Lynsey and have a darker skin with scales, or put it on Lady Rune and have tattoos plus scales?
    The scales on the human portion are part of the Indigo skins and are their own skins not an scale overlay
  • Ok, thanks.
  • FistyFisty Posts: 3,416
    The scales that blend the top of the tail into the human skin are part of the tail and use transparency so they go over all skins.
  • SkyWaySkyWay Posts: 7
    edited November 2022
    Question does anybody have the same issue using gen3 and the Laguna tail in 4.21 in the iray view port the model is not more loading and stays grey if i move the view port its very badly lagging which was never a issue for me in the 4.12 version same for gen 8 mermaid tails the only one that works is the cora mermaid tail
    Post edited by SkyWay on
    Same problem in version 4.15. Worked fine in 4.11.
