How Do I Fix The Discrepancy Between G8 Skin and G8.1 Skin
FauvistFauvist Posts: 2,291
edited January 27 in The Commons
How Do I Fix The Discrepancy Between G8 Skin and G8.1 Skin?  I recently started using Daz Studio 4.24 (on a Mac) so I could use characters with skin from 8.1 characters.
I'm using the exact same lights and light and render settings that I used in the old version of DAZ Studio.  Lights and settings I've used on hundreds of renders.
When I use them in Studio 4.24, inevitably the characters with the 8.1 skins are so light they're almost completely white.
Why is this happening?  And what do I do to fix it so they look like normal skins - like the skin the promo pictures for the characters.
I attached a screenshot of Genesis 8 & 8.1 charaters to show you what's happening.  Andre 8 is a pretty light skin, and Thomas 8.1 (from the look of the promo images) is a pretty dark skin.  The Genesis 8 characters render almost exactly the way they render in the old version of Studio I was using, and the Genesis 8.1 skins, although I can see that there is a skin texture there, the skin is way way too light.
NOTE: to see all the characters in the line up, you have to click on the attached file.
Post edited by Fauvist on
«13
  • Richard HaseltineRichard Haseltine Posts: 111,867
    They default to different shaders - Geness 8.1 often uses the PBR Skn shader, which was new wth 8.1 and so not used on Genesis 8 characters (certainly not the Daz own-brand characters). How are you lighting the scene?
  • FauvistFauvist Posts: 2,291
    I'm lighting the scene with a product called "Paper Tiger's Precision HDRI Lighting".
    There are no lights listed in the Scene tab, so I assume the only lighting is from an HDRI.  The headlights on the camera are definitely off.  I'm using the lighting product's default settings for tone mapping etc.
    I've used this specific light in this set for 6 years on hundreds of renders.  I haven't changed anything about the lighting.
    When I open the scene, I don't get a MISSING FILES message.
    I added Julian 9 to the scene and his skin renders as almost totally white, too.  He's the white character in the center.
    The Genesis 8 character's skin render as normal - the same as they render in the old version of Studio.  The background renders as a medium grey, as it always has.
    The render engine is NVIDIA (MDL).  I never noticed the MDL before.  I don't know what the MDL stands for.
    So there's something I'm not doing to get the G8.1 and G9 character skins to render correctly.
    1280 x 340 - 521K
  • GhostofMacbethGhostofMacbeth Posts: 1,777
    I think you are missing part of the shader. Mine don't render like that at all.
    I compared the surfaces tabs for specifically the SKIN.  The surfaces tab for all the Genesis 8 characters has a 5 in brackets, like this (5); and the surfaces tab for all the Genesis 8.1 characters has a 7 in brackets.  I'll attach the 2 tabs.  What does the 5 and 7 signify?  5 and 7 what?
    1088 x 1338 - 316K
    1066 x 1428 - 351K
    edited January 28
    On the Render Tab I clicked the "default" setting.  I changed the lighting product to a beach scene I've used dozens of times. The beach and the Genesis 8 characters rendered perfectly, just like they did in the old version of Studio.  The Genesis 8.1 and Genesis 9 characters again render very very light
    1164 x 847 - 549K
  • FJM1977FJM1977 Posts: 351
    The size of the group of surfaces you have selected.
    Thanks.  I guess that's not the problem then.
    These are some of the ones I have just in the basic DS lighting. They are not as blown out as what you are seeing. I don't have your lights that you used but you might test to see what they look like in the base set.
    1000 x 500 - 643K
    Where do you find Basic DS lightin in your content?  I didn't know there was a base set of lights.
    Thanks!
  • nemesis10nemesis10 Posts: 4,035
    Thanks!
    If you create a scene, there is a default HDRI that loads which is the basic light. My own guess is that you have loaded enough characters that you have run out of graphics memory so one of them is glitching.  Try deleting one figure and see if it renders the same.
    Yeah, just I loaded the characters and rendered and then changed the dome roation to sort of match yours.
    Thanks!
    Ok, I'm trying it.  First I opened a NEW scene. Second I loaded Torment 8,1, and he load with no textures at all.  Then I loaded Julius 9 and he also had no texture at all.  Then I put bathing suits on them.  I didn't add or touch the lighting.  I didn't touch the render settings.  And I hit render.  And it's worse than all the previous renders.
    1322 x 1676 - 2M
    edited January 28
    So I went into the content tab and applied Julian 9 and Torment 8.1 skin textures and hit render.
    So I can see there are skin textures on both of them.  They both look awful.  Torment is still no more visible than he was in the previous renters.  Julian has sort of skin coloured skin, but it looks about 1% as good as any Genesis 8 Character.
    I don't know why the background is black this time bedcause I literally didn't touch any other settings.
    665 x 847 - 161K
    I spent 11 hours today trying to get these 8.1 and 9 characters to render properly.
    It must be the version of Studio I'm using.  In the next day or two I'll get rid of it and download a fresh Studio and try again.
  • vwranglervwrangler Posts: 5,053
    edited January 28
    The 5 and 7 just mean that you have "Consolidate Properties" checked.
    More importantly, it looks like you've somehow got 3Delight shaders on your 8.1 characters. The image for your G8.1 characters shows "Daz Studio Default" as the shader, and that's a 3Delight shader, not an Iray shader. The G8.1 shader normally says "PBRSkin".
    I think you may need to redownload the Default Studio Resources; the only reason that it would be throwing 3Delight shaders on an 8.1 character -- that I can think of, anyway -- is because the PBRSkin shaders aren't present and so Studio doesn't know what the texture shader is telling it and it has to default to 3Delight.
    Given the lighting issues you've also mentioned, uninstalling and reinstalling Studio and its resources may be the best way to go, as you've mentioned. Note that installing the most recent version of Studio will remove 3Delight from your system completely.
    Post edited by vwrangler on
    edited January 28
    First, I updated DIM to the newest version, then I uninstalled the character Torment 8.1, and then using DIM downloaded it again, and installed it.  Then I uninstalled the Genesis 9 Starter Essentials, and then downloaded and reinstalled them. I can't find any 8.1 Starter Essentials - are there such files?  Where are they?  How do I download them?
    I loaded Torment 8.1 and went to the folder in my Content window and opened the Torment 8.1 Materials folder and manually clicked on the materials to apply them to the figure.  Then I rendered it.  It's still slmost completely white.
    In the Torment 8.1 files there are no materials other than the Iray materials.  So that's what I clicked to load.  Are there other materials files that are missing?
    The Surfaces tab for the Torment 8.1 figure show that it still says:  Shader:  DAZ Studio Default (RSL).  Are there indeed files or something named PBRSkin ?  Somewhere?  How do I find them?  How do I install them?
    Thanks!
    2446 x 1746 - 2M
    2446 x 1746 - 2M
  • LeanaLeana Posts: 13,625
    G8.1 is included in G8 starter essentials.
    PBRSkin shader (and the various other DS base shaders) is in "Daz Studio default resources" pack.
    If the Daz Studio Default Resources pack is on a different hard drive than the G8.1 character and skin textures - would that cause my problem?  Is DAZ Studio smart enough to pull the default resources from one hard drive and the skin textures from a 2nd external hard drive?
  • ElorElor Posts: 4,226
    Genesis 8.1 is part of Genesis 8 Starter Essentials.
    Your problem is likely not related to Torment 8.1 or Genesis 9 Starter Essentials or any of the other figures using PBRSking you tried to load, but likely related to missing the PBR Skin shader itself which is, AFAIK, included in Daz Studio default ressources. Using PBRSkin will likely require a version of Daz Studio at least released around the time Genesis 8.1 was released:
    https://www.daz3d.com/downloader/customer/files#prod_13176
    Regarding the absence of missing files errors, plenty of warning and errors are silently logged by Daz Studio and are only visible by opening Daz Studio log file. You can open it by going to Help > Troubleshooting > View Log File…
    I'm usiing DAZ Studio 424.0.3 (64 bit).  Is that version supossed to work with PBR skin?
    The Log File is overwhelming.  What am I looking for?  How do I know if there is an error or missing file?
    Correction, I'm using 4.24.0.3 (64 bit)
    This is the file log for the 8.1 charcter:
    CONTENT 2TB 31 October 2014/My DAZ 3D Library/Runtime/Textures/Matari3D/Thomas for M81/Character/M3DThomasFaceEyeBrows.jpg", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2026-01-28 12:30:01.218 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "/Volumes/3D CONTENT 2TB 31 October 2014/My DAZ 3D Library/Runtime/Textures/Matari3D/Thomas for M81/Character/M3DThomasNormal.jpg", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2026-01-28 12:30:01.311 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "/Volumes/3D CONTENT 2TB 31 October 2014/My DAZ 3D Library/Runtime/Textures/Matari3D/Thomas for M81/Character/M3DThomasFaceBump02.jpg", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2026-01-28 12:30:01.325 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "/Volumes/3D CONTENT 2TB 31 October 2014/My DAZ 3D Library/Runtime/Textures/Matari3D/Thomas for M81/Character/M3DThomasMouth02.jpg", no selector, pixel type "Rgb", 2048x2048x1 pixels, 1 miplevel.
    2026-01-28 12:30:01.373 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "/Volumes/3D CONTENT 2TB 31 October 2014/My DAZ 3D Library/Runtime/Textures/Matari3D/Thomas for M81/Character/M3DThomasMouthNormal02.jpg", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2026-01-28 12:30:01.444 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "/Volumes/3D CONTENT 2TB 31 October 2014/My DAZ 3D Library/Runtime/Textures/Matari3D/Thomas for M81/Character/M3DThomasTorso.jpg", no selector, pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.
    2026-01-28 12:30:01.448 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "/Volumes/3D CONTENT 2TB 31 October 2014/My DAZ 3D Library/Runtime/Textures/Matari3D/Thomas for M81/Character/M3DThomasTorsoNormal.jpg", no selector, pixel type "Rgb", 2048x2048x1 pixels, 1 miplevel.
    2026-01-28 12:30:01.493 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "/Volumes/3D CONTENT 2TB 31 October 2014/My DAZ 3D Library/Runtime/Textures/Matari3D/Thomas for M81/Character/M3DThomasBodyAO.jpg", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2026-01-28 12:30:01.535 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "/Volumes/3D CONTENT 2TB 31 October 2014/My DAZ 3D Library/Runtime/Textures/Matari3D/Thomas for M81/Character/M3DThomasLegs.jpg", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2026-01-28 12:30:01.547 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "/Volumes/3D CONTENT 2TB 31 October 2014/My DAZ 3D Library/Runtime/Textures/Matari3D/Thomas for M81/Character/M3DThomasLegsNormal.jpg", no selector, pixel type "Rgb", 2048x2048x1 pixels, 1 miplevel.
    2026-01-28 12:30:01.593 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "/Volumes/3D CONTENT 2TB 31 October 2014/My DAZ 3D Library/Runtime/Textures/Matari3D/Thomas for M81/Character/M3DThomasLegsBump.jpg", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2026-01-28 12:30:01.696 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "/Volumes/3D CONTENT 2TB 31 October 2014/My DAZ 3D Library/Runtime/Textures/Matari3D/Thomas for M81/Character/M3DThomasBump.jpg", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2026-01-28 12:30:01.734 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "/Volumes/3D CONTENT 2TB 31 October 2014/My DAZ 3D Library/Runtime/Textures/Matari3D/Thomas for M81/Character/M3DThomasMouth01.jpg", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2026-01-28 12:30:01.763 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "/Volumes/3D CONTENT 2TB 31 October 2014/My DAZ 3D Library/Runtime/Textures/Matari3D/Thomas for M81/Character/M3DThomasMouthNormal.jpg", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2026-01-28 12:30:01.807 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "/Volumes/3D CONTENT 2TB 31 October 2014/My DAZ 3D Library/Runtime/Textures/Matari3D/Thomas for M81/Character/M3DThomasArms.jpg", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2026-01-28 12:30:01.830 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "/Volumes/3D CONTENT 2TB 31 October 2014/My DAZ 3D Library/Runtime/Textures/Matari3D/Thomas for M81/Character/M3DThomasArmsNormal.jpg", no selector, pixel type "Rgb", 2048x2048x1 pixels, 1 miplevel.
    2026-01-28 12:30:01.872 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "/Volumes/3D CONTENT 2TB 31 October 2014/My DAZ 3D Library/Runtime/Textures/Matari3D/Thomas for M81/Character/M3DThomasArmsBmp.jpg", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2026-01-28 12:30:01.905 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "/Volumes/3D CONTENT 2TB 31 October 2014/My DAZ 3D Library/Runtime/Textures/Matari3D/Thomas for M81/M3DThomasEyesolor08.jpg", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2026-01-28 12:30:01.924 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "/Volumes/3D CONTENT 2TB 31 October 2014/My DAZ 3D Library/Runtime/Textures/Matari3D/Thomas for M81/M3DThomasEyesolor03.jpg", no selector, pixel type "Rgb", 2048x2048x1 pixels, 1 miplevel.
    2026-01-28 12:30:01.959 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "/Volumes/3D CONTENT 2TB 31 October 2014/My DAZ 3D Library/Runtime/Textures/Matari3D/Thomas for M81/Character/M3DThomasEyescolor05Normal.jpg", no selector, pixel type "Rgb", 2048x2048x1 pixels, 1 miplevel.
    2026-01-28 12:30:02.001 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "/Volumes/3D CONTENT 2TB 31 October 2014/My DAZ 3D Library/Runtime/Textures/Matari3D/Thomas for M81/M3DThomasEyesolor05.jpg", no selector, pixel type "Rgb", 2048x2048x1 pixels, 1 miplevel.
    2026-01-28 12:30:02.042 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "/Volumes/3D CONTENT 2TB 31 October 2014/My DAZ 3D Library/Runtime/Textures/Matari3D/Thomas for M81/Character/M3DThomasHead.jpg", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2026-01-28 12:30:02.057 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "/Volumes/3D CONTENT 2TB 31 October 2014/My DAZ 3D Library/Runtime/Textures/Matari3D/Thomas for M81/Character/M3DThomasHeadNormal.jpg", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2026-01-28 12:30:02.090 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "/Volumes/3D CONTENT 2TB 31 October 2014/My DAZ 3D Library/Runtime/Textures/Matari3D/Thomas for M81/Character/M3DThomasHeadBump.jpg", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2026-01-28 12:30:02.162 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "/Volumes/3D CONTENT 2TB 31 October 2014/My DAZ 3D Library/Runtime/Textures/Matari3D/Thomas for M81/Character/ThomasEyeLashes (2).jpg", no selector, pixel type "Rgb", 2048x2048x1 pixels, 1 miplevel.
    2026-01-28 12:30:02.188 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "/Volumes/3D CONTENT 2TB 31 October 2014/My DAZ 3D Library/Runtime/Textures/Matari3D/Thomas for M81/Character/ThomasEyeLashes (1).jpg", no selector, pixel type "Rgb", 2048x2048x1 pixels, 1 miplevel.
    2026-01-28 12:30:02.193 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "/Volumes/3D CONTENT 2TB 31 October 2014/My DAZ 3D Library/Runtime/Textures/Matari3D/Thomas for M81/Character/YhomasTear.jpg", no selector, pixel type "Rgb", 1024x1024x1 pixels, 1 miplevel.
    2026-01-28 12:30:02.300 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "/Applications/DAZ 3D/DAZStudio4 64-bit/shaders/iray/resources/DTHDR-RuinsB-500.hdr", no selector, pixel type "Rgb_fp", 512x256x1 pixels, 1 miplevel.
    2026-01-28 12:30:02.303 Iray [INFO] - TRAV:DATABASE ::   1.0   TRAV   db   progr: Traversing scene.
    2026-01-28 12:30:03.950 Iray [INFO] - TRAV:DATABASE ::   1.0   TRAV   db   info : Traversing scene took 1.647 s.
    2026-01-28 12:30:04.177 Iray (Scene Traversal) : Initializing update
    2026-01-28 12:30:04.177 Iray (Scene Traversal) : Retrieving journal and checking for changes
    2026-01-28 12:30:04.177 Iray (Scene Update) : Updating LPE labels
    2026-01-28 12:30:04.177 Iray (Scene Update) : Updating geometry contexts
    2026-01-28 12:30:04.177 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating geometry contexts.
    2026-01-28 12:30:04.177 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating geometry.
    2026-01-28 12:30:04.177 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Importing scene graph.
    2026-01-28 12:30:04.487 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Auto instancing compression 1.0x (Full instancing compression 1.0x)
    2026-01-28 12:30:04.487 Iray (Scene Update) : Retrieving geometry
    2026-01-28 12:30:04.487 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Importing geometry for motion time 0
    2026-01-28 12:30:05.199 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Geometry import (1 triangle object with 11 M triangles, 1 instance yielding 11 M triangles) took 711.661 ms
    2026-01-28 12:30:05.199 Iray (Scene Update) : Updating motion transform data
    2026-01-28 12:30:05.199 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating motion transforms.
    2026-01-28 12:30:05.199 Iray (Scene Update) : Updating section objects
    2026-01-28 12:30:05.199 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating section objects.
    2026-01-28 12:30:05.199 Iray (Scene Update) : Updating materials
    2026-01-28 12:30:05.199 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating materials.
    2026-01-28 12:30:05.310 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : found 188 textures, 0 lambdas (0 unique)
    2026-01-28 12:30:05.310 Iray (Scene Update) : Updating environment
    2026-01-28 12:30:05.310 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating environment.
    2026-01-28 12:30:05.326 Iray (Scene Update) : Updating code
    2026-01-28 12:30:05.326 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating compiled material code.
    2026-01-28 12:30:05.326 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating compiled environment code.
    2026-01-28 12:30:05.326 Iray (Scene Update) : Updating textures
    2026-01-28 12:30:05.326 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating material textures.
    2026-01-28 12:30:05.330 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating environment textures.
    2026-01-28 12:30:05.330 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating BSDFs.
    2026-01-28 12:30:05.330 Iray (Scene Update) : Updating volumes
    2026-01-28 12:30:05.330 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating volumes.
    2026-01-28 12:30:05.330 Iray (Scene Update) : Updating lens data
    2026-01-28 12:30:05.330 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lens.
    2026-01-28 12:30:05.330 Iray (Scene Update) : Updating lights
    2026-01-28 12:30:05.330 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lights.
    2026-01-28 12:30:05.330 Iray (Scene Update) : Updating instance topology
    2026-01-28 12:30:05.330 Iray (Scene Update) : Updating flags
    2026-01-28 12:30:05.330 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating object flags.
    2026-01-28 12:30:05.331 Iray (Scene Update) : Updating backplate
    2026-01-28 12:30:05.331 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating backplate.
    2026-01-28 12:30:05.331 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating compiled backplate code.
    2026-01-28 12:30:05.331 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating backplate textures.
    2026-01-28 12:30:05.331 Iray (Scene Update) : Updating decals
    2026-01-28 12:30:05.331 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating decals.
    2026-01-28 12:30:05.335 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using iray core convergence estimate.
    2026-01-28 12:30:05.336 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Allocating 1-layer frame buffer
    2026-01-28 12:30:05.340 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using batch scheduling, caustic sampler disabled
    2026-01-28 12:30:05.340 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Initializing local rendering.
    2026-01-28 12:30:05.341 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CPU: using 16 cores for rendering
    2026-01-28 12:30:05.341 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering with 1 device(s):
    2026-01-28 12:30:05.341 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
    2026-01-28 12:30:05.342 Iray [INFO] - IRAY:RENDER ::   1.48  IRAY   rend progr: CPU: Processing scene...
    2026-01-28 12:30:05.342 Iray (Scene Access) : Retrieving geometry
    2026-01-28 12:30:05.342 Iray [INFO] - IRAY:RENDER ::   1.25  IRAY   rend info : Initializing Embree
    2026-01-28 12:30:06.693 Iray (Scene Access) : Retrieving volumes
    2026-01-28 12:30:06.694 Iray (Scene Access) : Retrieving textures
    2026-01-28 12:30:20.476 Iray (Scene Access) : Retrieving flags
    2026-01-28 12:30:20.476 Iray (Scene Access) : Retrieving section objects
    2026-01-28 12:30:20.476 Iray (Scene Access) : Retrieving lights
    2026-01-28 12:30:20.476 Iray [INFO] - IRAY:RENDER ::   1.25  IRAY   rend info : Importing lights for motion time 0
    2026-01-28 12:30:20.476 Iray [INFO] - IRAY:RENDER ::   1.25  IRAY   rend info : Initializing light hierarchy.
    2026-01-28 12:30:20.477 Iray [INFO] - IRAY:RENDER ::   1.25  IRAY   rend info : Light hierarchy initialization took 97.990 us
    2026-01-28 12:30:20.477 Iray (Scene Access) : Retrieving materials
    2026-01-28 12:30:20.481 Iray (Scene Access) : Compiling custom code
    2026-01-28 12:30:20.481 Iray (Scene Access) : Retrieving environment
    2026-01-28 12:30:20.485 Iray (Scene Access) : Retrieving backplate
    2026-01-28 12:30:20.485 Iray (Scene Access) : Retrieving decals
    2026-01-28 12:30:20.485 Iray (Scene Access) : Retrieving motion transform data
    2026-01-28 12:30:20.485 Iray (Scene Access) : Retrieving lens data
    2026-01-28 12:30:20.486 Iray [INFO] - IRAY:RENDER ::   1.48  IRAY   rend info : CPU: Scene processed in 15.143s
    2026-01-28 12:30:20.488 Iray [INFO] - IRAY:RENDER ::   1.48  IRAY   rend info : CPU: Allocated 13.486 MiB for frame buffer
    2026-01-28 12:30:20.684 Iray [INFO] - IRAY:RENDER ::   1.48  IRAY   rend info : Allocating 1-layer frame buffer
    2026-01-28 12:30:20.753 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00001 iteration after 15.411 s.
    2026-01-28 12:30:20.774 Iray (Scene Traversal) : Initializing update
    2026-01-28 12:30:20.774 Iray (Scene Traversal) : Retrieving journal and checking for changes
    2026-01-28 12:30:20.888 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00002 iterations after 15.546 s.
    2026-01-28 12:30:21.259 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00004 iterations after 15.917 s.
    2026-01-28 12:30:21.974 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00008 iterations after 16.633 s.
    2026-01-28 12:30:22.864 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00013 iterations after 17.522 s.
    2026-01-28 12:30:23.751 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00018 iterations after 18.409 s.
    2026-01-28 12:30:24.632 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00023 iterations after 19.291 s.
    2026-01-28 12:30:25.534 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00028 iterations after 20.192 s.
    2026-01-28 12:30:26.466 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: 6.70% of image converged
    2026-01-28 12:30:26.487 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00033 iterations after 21.145 s.
    2026-01-28 12:30:26.500 Iray (Scene Traversal) : Initializing update
    2026-01-28 12:30:26.501 Iray (Scene Traversal) : Retrieving journal and checking for changes
    2026-01-28 12:30:27.337 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00038 iterations after 21.995 s.
    2026-01-28 12:30:28.404 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00044 iterations after 23.063 s.
    2026-01-28 12:30:29.685 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00051 iterations after 24.343 s.
    2026-01-28 12:30:31.146 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00059 iterations after 25.805 s.
    2026-01-28 12:30:32.880 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: 16.15% of image converged
    2026-01-28 12:30:32.894 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00068 iterations after 27.552 s.
    2026-01-28 12:30:33.013 Iray (Scene Traversal) : Initializing update
    2026-01-28 12:30:33.013 Iray (Scene Traversal) : Retrieving journal and checking for changes
    2026-01-28 12:30:34.923 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00078 iterations after 29.581 s.
    2026-01-28 12:30:37.125 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00088 iterations after 31.784 s.
    2026-01-28 12:30:39.381 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: 31.03% of image converged
    2026-01-28 12:30:39.397 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00099 iterations after 34.055 s.
    2026-01-28 12:30:39.416 Iray (Scene Traversal) : Initializing update
    2026-01-28 12:30:39.417 Iray (Scene Traversal) : Retrieving journal and checking for changes
    2026-01-28 12:30:42.203 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00112 iterations after 36.861 s.
    2026-01-28 12:30:44.849 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00124 iterations after 39.508 s.
    2026-01-28 12:30:44.868 Iray (Scene Traversal) : Initializing update
    2026-01-28 12:30:44.868 Iray (Scene Traversal) : Retrieving journal and checking for changes
    2026-01-28 12:30:47.907 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: 57.07% of image converged
    2026-01-28 12:30:47.907 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00138 iterations after 42.566 s.
    2026-01-28 12:30:51.986 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00153 iterations after 46.645 s.
    2026-01-28 12:30:52.007 Iray (Scene Traversal) : Initializing update
    2026-01-28 12:30:52.007 Iray (Scene Traversal) : Retrieving journal and checking for changes
    2026-01-28 12:30:54.223 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00162 iterations after 48.882 s.
    2026-01-28 12:30:57.090 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: 72.22% of image converged
    2026-01-28 12:30:57.116 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00173 iterations after 51.775 s.
    2026-01-28 12:30:57.137 Iray (Scene Traversal) : Initializing update
    2026-01-28 12:30:57.138 Iray (Scene Traversal) : Retrieving journal and checking for changes
    2026-01-28 12:30:59.623 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00184 iterations after 54.282 s.
    2026-01-28 12:31:01.366 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00192 iterations after 56.025 s.
    2026-01-28 12:31:03.336 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00201 iterations after 57.994 s.
    2026-01-28 12:31:03.358 Iray (Scene Traversal) : Initializing update
    2026-01-28 12:31:03.358 Iray (Scene Traversal) : Retrieving journal and checking for changes
    2026-01-28 12:31:05.408 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: 82.34% of image converged
    2026-01-28 12:31:05.408 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00211 iterations after 01:00.066.
    2026-01-28 12:31:07.692 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00222 iterations after 01:02.350.
    2026-01-28 12:31:09.202 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00229 iterations after 01:03.860.
    2026-01-28 12:31:09.222 Iray (Scene Traversal) : Initializing update
    2026-01-28 12:31:09.224 Iray (Scene Traversal) : Retrieving journal and checking for changes
    2026-01-28 12:31:10.793 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00236 iterations after 01:05.451.
    2026-01-28 12:31:12.390 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: 88.08% of image converged
    2026-01-28 12:31:12.390 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00243 iterations after 01:07.048.
    2026-01-28 12:31:14.036 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00250 iterations after 01:08.694.
    2026-01-28 12:31:15.219 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00255 iterations after 01:09.877.
    2026-01-28 12:31:15.249 Iray (Scene Traversal) : Initializing update
    2026-01-28 12:31:15.249 Iray (Scene Traversal) : Retrieving journal and checking for changes
    2026-01-28 12:31:16.325 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00260 iterations after 01:10.983.
    2026-01-28 12:31:17.460 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00265 iterations after 01:12.118.
    2026-01-28 12:31:18.682 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00270 iterations after 01:13.340.
    2026-01-28 12:31:19.795 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: 90.57% of image converged
    2026-01-28 12:31:19.795 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00275 iterations after 01:14.454.
    2026-01-28 12:31:21.068 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00281 iterations after 01:15.726.
    2026-01-28 12:31:21.092 Iray (Scene Traversal) : Initializing update
    2026-01-28 12:31:21.092 Iray (Scene Traversal) : Retrieving journal and checking for changes
    2026-01-28 12:31:22.095 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00286 iterations after 01:16.753.
    2026-01-28 12:31:23.149 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00291 iterations after 01:17.807.
    2026-01-28 12:31:24.173 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00296 iterations after 01:18.831.
    2026-01-28 12:31:25.260 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00301 iterations after 01:19.918.
    2026-01-28 12:31:26.384 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: 91.88% of image converged
    2026-01-28 12:31:26.391 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00306 iterations after 01:21.049.
    2026-01-28 12:31:26.413 Iray (Scene Traversal) : Initializing update
    2026-01-28 12:31:26.413 Iray (Scene Traversal) : Retrieving journal and checking for changes
    2026-01-28 12:31:27.509 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00311 iterations after 01:22.167.
    2026-01-28 12:31:28.498 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00315 iterations after 01:23.156.
    2026-01-28 12:31:29.381 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00319 iterations after 01:24.039.
    2026-01-28 12:31:30.266 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00323 iterations after 01:24.924.
    2026-01-28 12:31:31.080 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00327 iterations after 01:25.738.
    2026-01-28 12:31:32.158 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00332 iterations after 01:26.816.
    2026-01-28 12:31:32.231 Iray (Scene Traversal) : Initializing update
    2026-01-28 12:31:32.231 Iray (Scene Traversal) : Retrieving journal and checking for changes
    2026-01-28 12:31:33.180 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: 93.30% of image converged
    2026-01-28 12:31:33.180 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00337 iterations after 01:27.838.
    2026-01-28 12:31:34.151 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00342 iterations after 01:28.809.
    2026-01-28 12:31:34.942 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00346 iterations after 01:29.600.
    2026-01-28 12:31:35.732 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00350 iterations after 01:30.390.
    2026-01-28 12:31:36.741 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00355 iterations after 01:31.399.
    2026-01-28 12:31:37.778 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00360 iterations after 01:32.436.
    2026-01-28 12:31:37.810 Iray (Scene Traversal) : Initializing update
    2026-01-28 12:31:37.810 Iray (Scene Traversal) : Retrieving journal and checking for changes
    2026-01-28 12:31:38.822 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00365 iterations after 01:33.480.
    2026-01-28 12:31:39.700 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: 94.44% of image converged
    2026-01-28 12:31:39.700 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00369 iterations after 01:34.358.
    2026-01-28 12:31:40.530 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00373 iterations after 01:35.188.
    2026-01-28 12:31:41.376 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00377 iterations after 01:36.034.
    2026-01-28 12:31:42.234 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00381 iterations after 01:36.892.
    2026-01-28 12:31:43.070 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00385 iterations after 01:37.728.
    2026-01-28 12:31:43.090 Iray (Scene Traversal) : Initializing update
    2026-01-28 12:31:43.090 Iray (Scene Traversal) : Retrieving journal and checking for changes
    2026-01-28 12:31:43.870 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00389 iterations after 01:38.528.
    2026-01-28 12:31:44.679 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00393 iterations after 01:39.337.
    2026-01-28 12:31:45.505 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00397 iterations after 01:40.163.
    2026-01-28 12:31:46.330 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: 95.01% of image converged
    2026-01-28 12:31:46.330 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00401 iterations after 01:40.988.
    2026-01-28 12:31:46.343 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Convergence threshold reached.
    2026-01-28 12:31:47.368 [INFO] :: Saved image: /Users/anon/Library/Application Support/DAZ 3D/Studio4/temp/render/r.png
    2026-01-28 12:31:47.369 [INFO] :: Finished rendering.
    2026-01-28 12:31:47.691 [INFO] :: Total Rendering Time: 2 minutes 1.43 seconds
    2026-01-28 12:31:47.702 [INFO] :: Loaded image: r.png
    2026-01-28 12:31:47.726 [INFO] :: Saved image: /Users/anon/Library/Application Support/DAZ 3D/Studio4/temp/RenderAlbumTmp/Render 4.jpg
    So that's the file log for 1 character.  What am I looking for. (I changed my name to "anon" twice in the last 5 lines.)
    OK!  There's ERRORS.  Many say pbrskin .  So there are errors related to the pbrskin.  How do I fix it?
    1988 x 1632 - 881K
  • felisfelis Posts: 6,603
    Have you installed default ressources?
    And if you look at that path, does the file then exist?
  • IceCrMnIceCrMn Posts: 2,334
    edited January 28
    You'll need to delete the package to force DIM to download the new one that has the PBRSkin shader.
    So find the package in DIM
    Right click on it and Delete it.
    Then uninstall it.
    Now reinstall it.
    1409 x 1070 - 182K
    1367 x 909 - 111K
    Post edited by IceCrMn on
    edited January 28
    Then uninstall it.
    Now reinstall it.
    OK.  I uninstalled the resources and am reinstalling them now.  Here's another batch of errors that are from the same log entry as above (not from the log entry after I reinstalled the resources)
    2170 x 1902 - 1M
    The log says it's looking in a Connect library for it.
    Do you have the deafult resources installed twice?
    Once in DIM and again with Connect?
    If so, you need to uninstall it from Connect.
