Genitals are no longer adapted
schwarzertheaschwarzerthea Posts: 19
Suddenly I can no longer load genitals ( all Anatomy ) onto a character... all characters are affected...
I've tried re-importing the metadata and reinstalling the genital plugins, but without success!
please Help
Post edited by schwarzerthea on
  • crosswindcrosswind Posts: 9,701
    I've never seen such an issue before... even if you didn't select the character, the genital figure could've been loaded into the scene but just not fitted to the character ~~
    With the character selected, make sure you load the genital wearable preset... not any material preset or scripts.
    What is a genital plugin ?  Have you checked DS log ?
  • Richard HaseltineRichard Haseltine Posts: 109,129
    Which tool is checked in the Tools menu? If it is one of the geometry or figure editing tools that will stop GeoGrafts from grafting, try selecting the Universal tool and see if the issue goes away.
    Right ~ better well describe your issue. If you mean the genital figure cannot be correctly fitted / conformed to the figure (sort of floating...), press Alt Shift + U.
    THANKS @CROSSWIND for the tip about the keyboard shortcut....
