Cyberpunk Courier Robot Poses
Mutant-XMutant-X Posts: 12
edited January 21 in Product Suggestions
Are there any poses available for the Cyberpunk Courier Robot? I have been trying uses the poses from my Library, but none work.
  • felisfelis Posts: 6,049
    edited January 21
    Link to product. https://www.daz3d.com/cyberpunk-courier-robot
    I will assume the rigging is different, and therefor you can't use existing poses.
    I can see the PA has done other robots, but no poses.
    So you will probably have to do it by hand.
    You could save some partial poses when you have done them, so you can reuse them another time.
    Post edited by felis on
  • Richard HaseltineRichard Haseltine Posts: 109,028
    Moved to Product Suggestions as it is not a Daz Studio application topic.
  • crosswindcrosswind Posts: 9,686
    edited January 22
    Actually you can make nearly all of the Pose Presets from Genesis figures work on this stand-alone robot directly... by changing Node Names of its Bones ~ Let's assume you want to use G9 Poses on it.
    1) Open Joint Editor (Alt Shift + J), select Robot's Head bone, right-click in Viewport > Edit > Rename Node... (screenshot 1) Change Node Name to neck1 by referring to a G9 Base figure. (screenshot 2)
    2) Select Torso bone, change its Node Name to spine3 (screenshot 3).
    3) In the same way, by referring to G9 figure, modify Node Names of bones accordingly: Left Collar > l_shoulder, Left Arm > l_upperarm, Left Arm Bend > l_forearm, Left Hand > l_hand, Left ThumbA > l_thumb1, Left ThumbB > l_thumb2, Left Leg > l_thigh, Left Leg Bend > l_shin, Left Foot > l_foot.  Then make the modification to the Bones on the right, i.e. change prefix letter from l to r.
    It's a once and for all solution. After modifying the Node Names, save this Robot figure as a Scene Subset. Load the Subset next time. (If you have some Pose Converters, e.g. you can load G8 Pose Preset to this figure as well...)
    Now, load a G9 Pose Preset on the Robot. (screenshot 4 ~ 5). Ctrl + D. Then you just need to finetune the pose, e.g.  this robot has no Twist Bones, so mostly you need to twist / side-side some bones as needed ,etc. (as well as some finger bones ~~)
    This way can save a lot of time for you ~~
    2560 x 1392 - 833K
    2560 x 1392 - 836K
    2560 x 1392 - 838K
    2560 x 1392 - 957K
    2560 x 1392 - 1M
    Post edited by crosswind on
