Anyone flip a hair product (left to right)
junk
I want to take this product called Side Swept Glam and change the side to where the right side hands down instead of the left. Is this possible?
I've flipped a pose but never a product and don't see anything that would do such.
Post edited by junk on
Select the root object of the hair and scale it to -100% on the x-axis. This works for pretty much any object you want to reverse, including curves hair.
wouldn't it be nice if there was a way to "like" posts like in facebook
But it does bring up a question for Richard.
If you do the reverse X and then save if as a scene subset does modified version come back reversed but with a normal X for the new object?
I remember years ago where I reversed an object, a piece of bric-a-brac to use on a house and subsequently the scene began to crash, took me a long time to isolate that it was that one object that caused the crashes. And it was not originally created in daz but you would that that a basic imported object would be just like a daz object. And I have imported hundreds over the years and that was the only one that caused issues.
This is how I do it (works for dForce hair):
Now you have a mirroring morph saved to the hair, and you can use it now and when you load the hair in the future.
I don't have Side Swept Glam Hair. Here is an example with Bixie Cut Hair (I only loaded and mirrored the Main hair, and didn't bother with the strays, but they can be mirrored with the same technique).
You can use this same technique to create morphs for dForce hair, by moving vertices around in edit or sculpt mode in Blender, instead of mirroring the whole hair.
No matter saving it as a Wearable Preset or a Scene Subset, the hair can be loaded with the reversed shape as well as X Scale set as -100% ~~
Man you guys are awesome! Thank you very much crosswind, barbult and Timberwolf!
Ended up flipping a different hair all together but love the results here.
https://www.daz3d.com/mirror-geometry-for-genesis-9
https://www.daz3d.com/mirror-geometry [for genesis 8, dunno if it does 8.1 too]
https://www.daz3d.com/mirror-geometry-for-genesis-3
I have the latter two, but I've never used them. Riversoft Art's scripts are usually pretty good though.
Wow! That sounds so easy Blender normally makes my brain melt. I may have to give it another try.
Be sure you heed the Daz Studio part about selecting the Geometry Editor tool.
