Rendered image sizing
Tabian
Hi, can anyone tell me how to increase the size of the image rendering...?
Tabian
You would do that from Render Settings. Go to Window > Panes (Tabs) > Render Settings to see the pane if it is not visible already, then look under General > Dimensions. It is the same for both Iray and 3DL.
The settings will not let me make changes, any thing els I have to do..?
Make sure the pulldown is set to "Custom" and not to a preset size.
"Big 10-4" Mr. Fix that's done the trick...
Thank you...
