Rendered image sizing
Hi, can anyone tell me how to increase the size of the image rendering...?
    You would do that from Render Settings.   Go to Window > Panes (Tabs) > Render Settings to see the pane if it is not visible already, then look under General > Dimensions.   It is the same for both Iray and 3DL.
  • TabianTabian Posts: 76
    The settings will not let me make changes, any thing els I have to do..?
  • fixmypcmikefixmypcmike Posts: 19,735
    Make sure the pulldown is set to "Custom" and not to a preset size.
    "Big 10-4"  Mr. Fix that's done the trick...
    Thank you...
