Mesh hair to curve hair conversion error occurred
In Blender 4.5, when using the hair tool(Diffeomorphic), Failed to convert tubes to hair curves? The hair asset is Rita Hollywood Curls G8.
Post edited by miner123 on
This is already answered.
https://bitbucket.org/Diffeomorphic/import_daz/issues/2614/
Sagan handles open and closed tubes, as well as cards. Give the beta a try: https://iwasserious.com/sagan4.zip
I tried converting Rita Hollywood Curls G8 to curve hair using sagan4, but after importing it into Blender, the curve hair ended up empty
Wow, the geometry must be truly bizarre, then. I don't have that asset, to debug this.
Actually, it was on sale, cheap.
Worked for me... did you use settings something like in the image?
Forgot to include the image.
Same settings as yours, after exporting and importing into Blender, the hair curve is empty
Are you using the latest beta?
I use https://iwasserious.com/sagan4.zip
Enable "Log Details" under the Help menu, and try again. Maybe the log will tell us what is going on.
my sagan log
The log looks fine. There's go tot be something different about your setup, but I don't know what it is; I can't reproduce what you're seeing.
