Convert blender to.obj
Philippi_Child
Can I convert a blender file to .obj to use in Daz studio? I know there is a program in the store for converting items to use in DS. But I'm cheaping out at the moment. Lol
You should be able to export from Blender as OBJ - make sure you include the UVs. On importing into DS, the modo preset seems to work
Export to Wavefront OBJ format via Blender > File > Export > Wavefront (.obj) with the settings in attached screenshot 1. Them import in DS File > Import.... (Wavefront Object format) with default settings in screenshot 2.
However, in quite a lot of cases, especially when the models are made with some complex Modifiers in Blender, you'll probably find unexpected result and/or artifacts on the imported objects in DS. So there're alternative exporters like Better FBX Importer / Exporter that can really help and are cheaper than Blender to DS plugin (this plugin cannot work well in some of above-mentioned cases either ...)
You may refer to this thread : https://www.daz3d.com/forums/discussion/comment/9043001/#Comment_9043001
