Need to know: Changing the default UV set
RAMWolff
in The Commons
Hi,
I thought I had some notes about how to change the UV set out for another one. I can't use the common way using the transfer utility or the Update Geometry path because the clothing item is a refitted one from male to female so it's been resized and shaped to fit her form but like a dummy I used the wrong obj and now I'm stuck as the uv set I need is part of the obj I should have used.
Is there a way to get that UV set over to the refitted clothing item set to default?
Thanks for the help
Richard
Select the object in both Scene and Surfaces tab, and from the Surfaces tab in the menu drop-down select "Load UV Set...". You should then be able to load it directly from the other object. You can set it as default from the Parameter Settings cog.
I'll have to try that at some point. Got it fixed the long way around. Sorry it took me so long to post.... been REALLY busy....
