Need to know: Changing the default UV set
RAMWolffRAMWolff Posts: 10,381
Hi,
I thought I had some notes about how to change the UV set out for another one.  I can't use the common way using the transfer utility or the Update Geometry path because the clothing item is a refitted one from male to female so it's been resized and shaped to fit her form but like a dummy I used the wrong obj and now I'm stuck as the uv set I need is part of the obj I should have used.
Is there a way to get that UV set over to the refitted clothing item set to default?
Thanks for the help
Richard
  • Select the object in both Scene and Surfaces tab, and from the Surfaces tab in the menu drop-down select "Load UV Set...".  You should then be able to load it directly from the other object.  You can set it as default from the Parameter Settings cog.
  • RAMWolffRAMWolff Posts: 10,381
    I'll have to try that at some point.  Got it fixed the long way around.  Sorry it took me so long to post.... been REALLY busy....
