installing victoria 4.2 into poser 13
Trying to install daz victoria 4.2 into a windows11 machine running poser13.  Everything installs, although maybe into the wrong directory, though both the base morphs and the ++ morphs do/will not appear in the parameter window and thus are not usable.   What am I missing, or doing wrong ?  Any advice is most welcome.
  • Did you run the
    /Runtime/Libraries/!DAZ/DzCreateExPFiles-v4
    file from a file browser? That is needed to build the index of installed morphs that the figure file loads - it needs to be redone every time you install or uninstall an ExP product (morph packs and some characters)
  • Yes, she needs to be 'activated' offline with the .BAT scripts, the first time you install her. Same for M4. Then they can accept the Morphs++ and other packages.
  • WandWWandW Posts: 2,903
    If you install with DIM, it initializes them automagically.
  • Richard HaseltineRichard Haseltine Posts: 109,124
    Not my recollection, but of course if you use DS and install everything you will get PowerLoader which will do the job.
