Looking for shorts for a G8F
tyra_oeildeloup
in The Commons
Greetings, I'm looking for a fantasy short with opened sides like in this screenshot (Dragon Dogma 2)
Thanks for reading !
Or maybe Sue Yee's Strappy Jeans?
Wow, thanks a lot MelanieL ! It fits well to what I'm looking for. Thanks Richard, I remember the elven Strapped from ES, used it a lot on Poser 7 back in the day, but I'm afraid to be unable to use it correctly on G8 -_-'
If you were handy with Photoshop or a similar program you might be able to create a cutout map for a pair of shorts that are otherwise suitable.
I couldn't help but convert that old Aeon Soul (Every Soul?) to G8F.
I tried autofit, and the pants behaved decently, but some of the strings in the top deformed. So I decided to do a manual conversion.
Then I realised the converted tops strings didn't behave so nice with different sizes breast, so I decided to simulate the strings. That didn't go so well as dForce (and DS) just froze. Only a kill could solve it. Then I realised that there was a number of double verteces in the top. After having taking care of that it behaved properly.
Felis, you did a really good work, I can only imagine the time it took to make such a thing !
I could have done that, but one of the laces in the top deformed badly when autofitting (why I didn't investigate), so I decided to take the V4 top and G8F into blender, and just fit it there.
When I then realised that Daz couldn't simulate it, I guessed that there might be some double vertecex. And cleaining that up in blender is easy. After that is was just a new transfer to G8F and it was good. It is only the laces that has dynamic strength for simulation. I furthernore lowered gravity to 0.1, else the laces would bend downwards.
I don't have it and it's not exactly cheap, but do you know about Blender Secrets?
https://www.3dsecrets.com/
Regarding your problem, I don't remember having Blender launching stuck at the last command I did, did you try to un-install it?
Edit: I forget, about the original topic.
I looked at the usual 'suspects', but could not find a fantasy looking strappy short: they are either too modern, or not for genesis 8, or both and the closest one (with a zip tie that will likely look a bit out of place in a fantasy settings) is the succubus outfit by Herschel Hoffmeyer.
https://www.daz3d.com/infernal-succubus-outfit-and-add-ons-for-genesis-8-female
You'll have to hide the straps for the stockings if you don't want to use them. A way to do so would be to create a Conditional Graft, Mada has a video on the subject:
I know there are longer pants which lace at the sides. The geometry editor could be ypur friend at shortening the pant legs.
