Looking for shorts for a G8F
Greetings, I'm looking for a fantasy short with opened sides like in this screenshot (Dragon Dogma 2)
Thanks for reading !
  • I really don't know anything exactly like that shown. However, Aery Soul is synonymous with fantasy for me. And their 'Elven Strapped' is a bit like it, and free, for V3/V4. So, if you have a V3 or V4 clone for G8, then Elven Strapped may be worth investigating. Regards, Richard.
  • MelanieLMelanieL Posts: 7,882
    Or  maybe Sue Yee's Strappy Jeans?
  • They'd be much better. Regards, Richard.
  • Wow, thanks a lot MelanieL ! It fits well to what I'm looking for. Thanks Richard, I remember the elven Strapped from ES, used it a lot on Poser 7 back in the day, but I'm afraid to be unable to use it correctly on G8 -_-'
  • If you were handy with Photoshop or a similar program you might be able to create a cutout map for a pair of shorts that are otherwise suitable.
  • felisfelis Posts: 6,602
    edited December 2025
    I couldn't help but convert that old Aeon Soul (Every Soul?) to G8F.
    I tried autofit, and the pants behaved decently, but some of the strings in the top deformed. So I decided to do a manual conversion.
    Then I realised the converted tops strings didn't behave so nice with different sizes breast, so I decided to simulate the strings. That didn't go so well as dForce (and DS) just froze. Only a kill could solve it. Then I realised that there was a number of double verteces in the top. After having taking care of that it behaved properly.
    900 x 1200 - 2M
    Post edited by felis on
  • Felis, you did a really good work, I can only imagine the time it took to make such a thing !
  • richardandtracyrichardandtracy Posts: 8,208
    That's interesting, @Felis, thanks. Am I right, that when you cut out the things you tried but didn't work, you'd 1) autofit to G8, 2) export as obj, 3) merge vertices in a modeller and export as a new obj, 4) import the new obj into DS, 5) then convert to figure, and 6) transfer rigging from G8F? Hope I've got that right. Regards, Richard.
    Post edited by richardandtracy on
    I could have done that, but one of the laces in the top deformed badly when autofitting (why I didn't investigate), so I decided to take the V4 top and G8F into blender, and just fit it there.
    When I then realised that Daz couldn't simulate it, I guessed that there might be some double vertecex. And cleaining that up in blender is easy. After that is was just a new transfer to G8F and it was good. It is only the laces that has dynamic strength for simulation. I furthernore lowered gravity to 0.1, else the laces would bend downwards.
  • Ahh. That's a shame. Blender and I are not on speaking terms. Well, I shout and scream, Blender never finishes the first command I ever tried to do. So long ago I no-longer remember what it was, but it's still there , incomplete and refusing to go away when I open the program, held over from the first time I ever used Blender. And none of the thousands of hours of video tutorials there are can ever help me. I simply can't learn from video. Text, yes, video, no. And are there any text tutorials? Not last time I looked. So, I now have a Blender free life. Regards, Richard.
  • ElorElor Posts: 4,225
    I don't have it and it's not exactly cheap, but do you know about Blender Secrets?
    https://www.3dsecrets.com/
    Regarding your problem, I don't remember having Blender launching stuck at the last command I did, did you try to un-install it?
    Edit: I forget, about the original topic.
    I looked at the usual 'suspects', but could not find a fantasy looking strappy short: they are either too modern, or not for genesis 8, or both and the closest one (with a zip tie that will likely look a bit out of place in a fantasy settings) is the succubus outfit by Herschel Hoffmeyer.
    https://www.daz3d.com/infernal-succubus-outfit-and-add-ons-for-genesis-8-female
    You'll have to hide the straps for the stockings if you don't want to use them. A way to do so would be to create a Conditional Graft, Mada has a video on the subject:
    Post edited by Elor on
  • JOdelJOdel Posts: 6,322
    I know there are longer pants which lace at the sides. The geometry editor could be ypur friend at shortening the pant legs.
