[Released] Ultimate Pose Converter Bundle for Genesis 9 [Commercial]
124»
  • jmucchiello said:
    I bought this bundle a while back in the expectation of using it. And I finally did. After creating the minion, there's a popup dialog telling you it was created. That's fine. But when I load the DUF again later, the dialog also pops up stopping mid-load until I hit OK. That's not so great. Anyway to prevent this from happening?
    Did you uncheck the Show Dialog Again checkbox?
  • jmucchiellojmucchiello Posts: 2,366
    No, because I didn't notice it. This is what I came here to find out. I'll check when I can. Thanks.
    You're welcome!
  • Ron KnightsRon Knights Posts: 2,779
    I'm sorry, I read this entire thread and remain confused.
    Is the product called Bone Minion or Pose Converter?
    Does one product convert all generations of poses? Or does one product convert Genesis 8 to Genesis 9?!
    The name of the series of products are Bone Minion, which act as Pose Converters. The Ultimate Pose Converter Bundle for Genesis 9 bundle contains all the products to convert poses FROM Genesis 9 TO other generations. No one of the Bone Minion products does every conversion.
    If you are looking for products to convert poses TO use with Genesis 9, look for products with a name FOR XXX Poses for Genesis 9, e.g., Bone Minion for Genesis 2 Poses for Genesis 9 converts Genesis 2 poses for use with Genesis 9.
    OK thanks.
    RiverSoft Art said:
    You're welcome!
    Found it. And it works. Thanks again.
    The best thing about this product is it's basically intuitive to use. So, thanks for that as well.
  • jmucchiello said:
    RiverSoft Art said:
    You're welcome!
    You're welcome for that too! I am so glad you like it. smiley
