Please help with black background in render.
Jan_Scrapper
in The Commons
I need to do some postwork and wanted some snow props and tree props as png images.
I am using My Cold Place for the major environment. My Cold Place | Daz 3D
I turned off My Cold Place props. I turned off the dome. I changed the the Draw Dome to off. I changed the background to not render.
I seached and have read a lot about black backgrounds, however not revlient to my problem, that I can tell.
Please, if you know what might be the problem, let me know. I just started with Daz Studio 4.24 a few months ago. I had used 4.15, I think, for years.
It's like the Cadillac of Daz Studio, however, I have so much to learn :)
Thank you for all of your help!!
A problem like this popped up with another user a couple of days ago. It could be CANVASES under your RENDER SETTINGS. If there are any presets within those windows, remove them. Should help if that's the problem.
Just a thought - are you saving as .jpg or .png? You'll need to be saving as png for a transparent background - sounds like you have everything else right.
I tried it and the only time a black background appeared was when I loaded the prop "My Cold Place Sky", which is a 3delight prop. Once I removed it again I had no problems. Even when I used the 3dl environment version I didn't get the black background in Iray.
If you want a tranparent background, then in the Environment Tab, the Type should be "None", not "Backdrop". However I would expect your background in this case to be white, not black.
Thank you so much, guys.
I attached my screenshots, saved as a png.
I am going to save the tree and the additional snow as Scene Subsets, create a new scene and try to get the same lighting without any background.
I have an appointment, so I cannot do it now.
This is what I am working on...see attached.
I had to render the fox in a seperate render because my computer kept crashing.
Now, I want to make him look like he really was part of the scene :)
I have already done some postwork, on the fox...removing part of his tail to show he is behind the Queen.
Again, I could easily save the props I want to a scene subset and render just them. It's those special lights that I am using. I don't know what I did :(
