I am expecting a new computer next week. It has a 4000 series nvidea card(sorry, don't have all the specs yet) A huge amount of storage I think 15tb of storage and 32gb ram. Will it run this newest version of Daz? I will have the exact specs next week. He told me but I was not in a place where I could write it down.
I'm adding a suggestion here to who ever updates this. When releasing a new version, it might be a really good idea to warn everyone to not update if their hardware specs become "unsupported" mainly in terms of graphic cards. In some cases, a lot of us are looking to upgrade machines in the next little while, so we won't mind using an outdated version of daz Studio until we're up to spec, but if suddenly the version update makes our current hardware incompatible we are out of luck, there is no download of older version that I am aware of. If you guys/gals can do that, I'm sure many would appreciate it. Or provide a means of downloading and re-installing an older version in the meantime. Thank you.
This is a thread about the DS 2025. In any event, DS 2025 hasn't change compatibility (beyond adding support for the 50x0 cards). The hardware and driver requirements for any Iray update get noted in the release thread, the Iray updates thread, the change log. {edit}amd the Evergreen thread https://www.daz3d.com/forums/discussion/727631/daz-studio-2025-6-25-2025-x-evergreen.
I just tried to export from Daz 2025 alpha a .dae file only to see it doesn't exist. Can someone tell me which version I should reinstall to get .dae export?
Thank you felis, I installed the 4.24 and saw it. I just "upgraded" to a rtx 5060ti and it has killed my workflow as the iray compile is from 2022 inside Daz and will not use my gpu for rendering. I wanna cry.
The Universal Viewport mode is interesting but will there be parity in lighting/exposure when it comes to changing modes between Iray, Filament, and Texture Shaded?
I am not sure what you are asking. If you mean, will Iay and Filament be item overrides with Universal mode then no - they don't work like other Drawstyles and so cannot be mixed in a single draw.
Sorry, I was unclear - When I am working on scenes, switching between Iray and Filament seems to keep the scene decently lit but when I switch to Texture Shaded, it becomes too dark. I have to toggle Preview Lights (Ctrl+L) so the scene would be lit similarly as the other viewport modes. It seems like a bug to me but wanted to be sure I was not seeing some odd behavior or if it was something I did.
Also, will there be documentation on what surface settings will be able to be previewed in Filament and Texture shaded (i.e. displacement, opacity, normals, etc...)?
And will shadows be something available in Texture Shaded?
Yes, it will.
Thank you.
Anything beside DS 6 (DS 2025) .
You can do all your workflow in DS 4 and save as a scene, and then open that in DS 6 amd render.
As noted in the Everygreen thread, the daz .dae exporter has been dropped and the format is now handled through the FBX exporter. https://www.daz3d.com/forums/discussion/727631/daz-studio-2025-6-25-2025-x-evergreen
