Base Daz3d opens to a white box
As the title says, the base Daz program (NOT Beta or Alpha) opens up into a white box.
Things I have tried;
-Uninstall all daz3d programs+cms
-Delete actions.dsx, customactions.dsx,layout.dsx,menus.dsx,toolbars.dsx from the roaming folder.
White box ? What does it look like ?
You can try loading a saved layout or default layout.
I can't access the program at all. All I get is the program starting and looking like a white box (most likely some sort of alert) when hovered over in the taskbar.
You can try this: https://www.daz3d.com/forums/discussion/738051/solved-daz-studio-opens-only-to-taskbar
THANK YOU. That did it!
