What is the "New Wspusher" and what does it do?
I just came upon this in the main menu under Create. I'm not sure if it is something new or something I just did not notice before. I can't find any documentation for it, and even Google only leads me to push modifiers. Can anyone enlighten me about what it is or how to use it?
In which version of DS?
4.24.0.3 Public Beta build.....Premier Subscription
I also have 4.24.0.3 Public build that does not have it, so it must be something with the Beta build.
waw, I don't have one and surv0101 has one I want it, right? And when do we get a WsPuller?
What's the difference in between 4.24.0.3 Public Beta build and 4.24.0.3 Public build ?
You can easiliy compare the installed plugins in each of them...
Or post a screenshot if possible ~
surv0101 said its a WsPusher not a WsPuller
not that that is enlightening
Public Build == Beta, the terms were getting hybridised
I don't know. A long time ago I downloaded the Beta build so I could be rendering on one instance of DS while I continued to work on the other. Now I just update both at the same time whenever the new updates come out. I don't see a big difference except for little things once in a while like this WSPusher. Here is a screenshot of it, but I can't seem to make it do anything, lol.
Check Help>About Installed Plug-ins, if you find the WSPusher plug-in listed click on it and look at the boittom of the dialogue, where it will give more information.
You can go to the folder: C:\Program Files\DAZ 3D\DAZStudio4 Public Build\plugins (or the application folder where you installed DS Public Build...), search by push , or especially check *.dll files not started with dz. You should be able to find the culprit.
Then remove the culprit DLL file from that folder. Relaunch DS.
It's a plugin called Worldspace Pusher [v1] [esteban gonzales] - A Daz plugin to create wave effect for all Nodes or only one target Node.
It has nothing to do with any DAZ build.
