What is the "New Wspusher" and what does it do?
I just came upon this in the main menu under Create. I'm not sure if it is something new or something I just did not notice before. I can't find any documentation for it, and even Google only leads me to push modifiers. Can anyone enlighten me about what it is or how to use it?
  • In which version of DS?
  • surv0101surv0101 Posts: 84
    edited November 2025
    4.24.0.3 Public Beta build.....Premier Subscription
    I also have 4.24.0.3 Public build that does not have it, so it must be something with the Beta build.
    Post edited by surv0101 on
    waw, I don't have one and surv0101 has one I want it, right? And when do we get a WsPuller?
  • crosswindcrosswind Posts: 10,347
    What's the difference in between 4.24.0.3 Public Beta build and 4.24.0.3 Public build ?
    You can easiliy compare the installed plugins in each of them...
    Or post a screenshot if possible ~
  • surv0101 said its a WsPusher not a WsPullercheeky
    not that that is enlightening
    Public Build == Beta, the terms were getting hybridised
    I don't know. A long time ago I downloaded the Beta build so I could be rendering on one instance of DS while I continued to work on the other.  Now I just update both at the same time whenever the new updates come out. I don't see a big difference except for little things once in a while like this WSPusher. Here is a screenshot of it, but I can't seem to make it do anything, lol.
    3840 x 2160 - 411K
  • Check Help>About Installed Plug-ins, if you find the WSPusher plug-in listed click on it and look at the boittom of the dialogue, where it will  give more information.
    You can go to the folder: C:\Program Files\DAZ 3D\DAZStudio4 Public Build\plugins (or the application folder where you installed DS Public Build...), search by push , or especially check *.dll files not started with dz. You should be able to find the culprit.
    Then remove the culprit DLL file from that folder. Relaunch DS.
  • It's a plugin called Worldspace Pusher [v1] [esteban gonzales] - A Daz plugin to create wave effect for all Nodes or only one target Node.
    It has nothing to do with any DAZ build.
