In the dark perhaps
Once again I have a problem which I think has an obvious solution, but the solution eludes me. For no apparent reason I seem to be unable to render images in either iRay or 3delight, and perhaps the reason is that my lighting isn’t working correctly.
I am including a few screen shots to illustrate the conditions and results…
Any help or advice would be much appreciated
  • felisfelis Posts: 5,720
    What is your background? Just an image in Environment tab?
  • deeahr2169deeahr2169 Posts: 482
    For simplicity i used the environment tab. However I do often used JPEG images overlaid onto a pane or cube.  At other times I use a part of a prop, for example the background from Stonemasons products can be very goood. Nothing seems to make any difference to the images in the curent rendering problem....
    OK for the record I removed Daz from my machine in its entirity and began anew. So I now have a clean version of Studio with the defualt content installed via DIM. It doesnt hurt to clean up occasionally and somewhere in all the files I have installed there may well be something causing this problem. Thigs is that only using the default content I have had to use G9 which I am not used to, but the principles remain the same, and unfortunatley so do the results of rendering.
    I am at a loss, help please!
    433 x 700 - 180K
    What is the difference betweem those where you can see the shpere and the other?
    What is Environment mode set to?
    Not sure about the question or indeed the answer.... However having bitten the bullet and re installed DS with no resolution I found out about the factory reset option, which I took. I need to make sure this works for everything that has to be reinstalled because as far as I can see i only have the preinstallled G9 content to test renders on but so far it works on this content and the resulting render in iRay looks okay to me...
    471 x 763 - 576K
