Show Us Your Bryce Renders! Part 9
Adding to Cart…
© 2025 Daz Productions Inc. All Rights Reserved.You currently have no notifications.
Tim - thanks for the link. I haven't reserved Windows 10, but the KB3035583 was installed, which I uninstalled. So far no notification and the laptop is working without any problems. I also chnaged the Windows Auto Update to check for updates and let me chose.... Thanks once again.
Vivien and Horo - Thanks to both. I'm still playing but uploading most to my Abstract Board on Pinterest.
Vivien - you got a very interesting design in your last render, awesome.
realy nice abstract renders
....great work
Yep, I am using LAA. I think there is something else than the memory size, but I don't know what.
Thanks for the positive words. Still, it is a pity not to have the nice texture anymore!
@vivien: very nice abstracts!
@Horo: Both are great!
@mermaid010: your abstracts are also wonderful. The first one looks like a weird record player.
Yes it is a pity, getting nice textures is very time-consuming. Maybe you will come up with something better.
There is a lesson in this for us all - save, save and save.
Thanks for your comments on my abstracts
Last three abstracts from me, for the 1st one I used a 2D disk as the object and the 3rd I tried Horo's method with 2 planes. I posted the others here: https://www.pinterest.com/maryole3/bryce-3d-abstracts/
@mermaid010: Of course you are right. We keep learning! And wonderful abstracts again. I like the second on best. Like a close-up of some robot insect head!
Thanks Hansmar
Stills of Wings 3D objects using elements from Horo’s and David’s new product.
http://www.daz3d.com/bryce-7-1-pro-environments-inclement-weather
Since you seem to have had quite a bit of fun with reflections, here's another little experiment.
First is the result (rendered 360 panoramic). Second shows the material setup (same scale used for both texture components). Three and four are textures for channel A and B. Fifth is the wireframe and the last the sky. Though any sky will do I chose to use a HDRI by Horo because I liked the colours.
Another addictive idea. Move the camera a bit within the cube, change max ray depth, play with mapping mode, without changing the HDRI you get new and new and new patterns and results. Which one of all those is the best?
Mermaid: nice abstracts from you.
Awesome Abstracts David and Horo.
David - thanks for the screenshots.
Horo - thanks for the comment.
Mermaid - thank you.
Experiment with light. The vase has a brass material, the brick wall and the floor materials I made years ago. Ambient light is from the WhiteSphere HDRI, I could have used a dome light. The main light is a spot with edge softness and a gel (or cookie, or gobo) from the library (barren winter tree).
Good light, Horo. However, brass is more similar to clay. :-)
We are talking about metals? They, too, I have.
This aluminum?
This is probably the bronze?
This is patinated bronze?
Do you think it looks like a brass?
Just remember that it is good work and some can always learn from your experience, helps them move forward as you continue to grow, and find things that help you move forward. Its all relative! Still great work (sorry for the delayed reply not sure why either I missed the notice or it burped and I didn't get it)
Slepalex - thank you. Yes, I took a glassware vase and just wanted it to look different. Clay would have worked as well but I wanted something that exhibits some gloss. The aim was lighting.
Very nice metals from you. The first aluminium looks more like pewter to me, but it very much depends on how it is polished and lit. Brass looks a bit green to me but then, not all brass looks like a trumpet.
Below some metals I found in my household: brass vase, pewter jug and cup, copper and silver jar.
Another render of a ventriloquest puppet. This puppet's body however, is made by Fil from Deviantart in 3ds Max. He also used the head I used in my previous render uploaded some time back here.
@mermaid010: nice renders of strange items.
@David Brinnen and Horo: Yes, reflections and changes of camera settings (or HDRI, or texture or position or.....) will keep us happy for a long time.
@Horo: I agree with Slepalex: your brass did not really look like brass to me. Your last set of metals (photo's aren't they?) are nice references.
@Slepalex: Wonderful textures. I really like them!
@launok: very nice render of this ventriloquest puppet and it's player. The English (or American?) word is so much nicer than the Dutch one, which would be 'belly speaker puppet' if translated directly. I guess in German something similar (Horo?)
Hansmar - thank you. Yes, ventriloquest translates in German the same as in Dutch, though "Bauchredner" doesn't sound as bad as "belly speaker" does.
Thank you all for your comments & your inspirational work...
vivien - I like your multireplicating torus & would like to do something similar.
mermaid010 - your hypermirror stuff is interesting.
David & Horo - I like your reflection experiments.
Slepalex - those are great textures.
This render is the result of following David's '4 minute Wings 3D Shell Extrude profect' video (without smoothing the object)...
Impressive renders here
This is my last render. After a lot of skin renders I thouhgt I make a step back (or further) to the things Bryce can do well: Landscape. Hope you like it. Rendered with IBL. Rendertime about 10 minutes. The rowing boat is from sharecg.
Some time back I have shared a Bryce scene with my own built fashion shop made in SketchUp. I have made interior scenes. All the props are from SketchUp Warehouse with Genesis Female character. But to use the rotation inside the scene for different views is quite hard and the lighting is just awfull. I really need to learn more about this.
Hi! I've been working on 3D'ing one of my favorite paintings: The Lovers, by Chris Achilleos.
Wonderful result, dragonfall1221 (for those interested, a poor version of the original can be seen here). Never knew of this artist, even though have indirectly seen his works re: posters and book covers etc., in the past.
Jay
@dragonfall1221: Very well done. Maybe the shadows are a bit too hard. Interesting that you replaced the bird (@Jamahoney: thanks for the link to the original) with a dragonfly
@launok: Your shop looks great. But I agree with you the lighting could be improved. It seems you are using the Bryce sun. Give the Cube Fill Light a try. It is not that difficult to use. As long as the Cube Fill Light is smaller than the room itself everything should be fine. BTW your ventriloquest scene also looks very well. If you are not quite happy with the skin try True Ambience. It immediatly makes the skin looking good. BTW generally speaking True Ambience is the best and easiest methode to improve the skin of DAZ3D figures dramatically.
@kootenay_photos: Well done.
@Jamahoney - Thank you! And thanks for providing a link to the original.
