• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Mixing two displacements from two Daz shells in Blender
jwcjaygainesjwcjaygaines Posts: 72
October 14 in Blender Discussion
Okay, so here's what I have going on. I have created a G8M in Daz and imported into Blender via Diffeomorphic. The model has two shells: the "Authoritarian" for his man-bits, and Jepe's Body Hair Project. The issue I'm having is that both use Displacement nodes in their group output, but only the Body Hair's one is plugged in to the material output, as it's the last in line. Normally, without the Body Hair Shell, the Authoritarian plugs in. So I need to figure out what node to use in the Body Hair's group to combine both Displacement maps together. This is an issue because I've recently learned how to render using Cycles without my laptop burning my apartment down, so the Displacement impacts the result more than it does in Eevee. If I just have the Authoritarian displacment plugged in, the pubic area where the graft is looks washed-out. If I just use the Body Hair displacement, it also looks wrong (way more displaced) than the surrounding geometry.
  • PadonePadone Posts: 4,019
    October 15 edited October 16
    I assume you're talking of diffeomorphic. Yes we adopted an approximation for material shells where only the top displacement is considered, now reported to Thomas to somewhat consider multiple displacements. Or you can use geonode shells instead, which will work fine with multiple displacements at the cost of duplicating the geometry, same as daz studio does.
    global settings > shell method: geonode
    https://bitbucket.org/Diffeomorphic/import_daz/issues/924/
    update. This is fixed in the last commit, now multiple displacements are considered for material shells too, an approximation is used which may give slightly different results compared to daz studio. Or as noted above use the geonode shells for accurate results.
    https://bitbucket.org/Diffeomorphic/import_daz/downloads/
    Post edited by Padone on October 16
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
