UltraScatter2 - Now in store!
12346»
  • barbultbarbult Posts: 26,262
    @felis It appears that the three instance groups consist of one instance group per original tree prop (look at the names Free_Tree1, Free_Tree2, Free_Tree3). When you delete two of the instance groups from the scene, are all the remaining trees, on the plane, instances of the SAME tree? Do all three tree props load at the world origin 0,0,0 when you manually just load the tree prop into your scene, or are some of them offset from world origin?
    Do you still have the test scene? If you scatter something other than those specific trees (perhaps tree props from UltraScenery), does it still happen?
  • richardandtracyrichardandtracy Posts: 7,174
    edited October 2025
    I've found with my <comparitively uncomplicated> array scripts that, provided the subsidiary nodes are parented to the top level one, that all subsidiary nodes get instanced along with the top one, meaning that in the case of 3 trees, they would stay as three trees in a group and be instanced as a group with the same relationship to each other.
    I wonder if that isn't quite happening here. Could it be that parented nodes are being instanced as a separate group?
    (In practice, with my scripts, instancing the group of nodes together was an advantage, because if the top node being instanced was a clothed character, the clothes were instanced with the character & couldn't get lost.)
    Regards,
    Richard
    Post edited by richardandtracy on
  • felisfelis Posts: 5,825
    Mystery solved.
    Only one tree was in world origin.
    When I moved them all to world origin and reimported they behaved as expected.
    felis said:
    Mystery solved.
    Good. Thanks for confirming the problem and fix.
  • AnEye4ArtAnEye4Art Posts: 852
    Island in the sea.
    2160 x 1215 - 5M
  • ArtiniArtini Posts: 10,330
    Very nice, @AnEye4Art
    Interesting island.
    I found an oddity in Ultrascatter.
    If a object has geometric centerweight away from the center, the distribution will be offset proportional with the center difference. I created 3 simple objects, where 2 where rotated 90 degree on the groundplane, the 3rd had a slight offset to a third site. The distribution will actually land far away from the area they should be distributed on.
    In the below are the 3 objects distributed on the plane, but the 2 with a heavy weight away for center enter up far away in that direction, whereals the 3rd with a minor weight off remained half on the plane and half outside.
    Firts image show the objects, and some of the 3rd distribution, and the second an overview of where everthing is distributed.
    866 x 708 - 95K
    868 x 659 - 46K
    edited October 2025
    I have just tested and the objects were scattered away from the plane, placed in the camera view.
    It is pretty easy to move instances back to the place, I wanted them, but I have not encountered
    such behavior previously.
    1920 x 1080 - 729K
    Post edited by Artini on
    Mountain view
    2160 x 1215 - 5M
    Old stomping grounds
    2160 x 1215 - 5M
  • Storm's A Comin.
    1920 x 1080 - 4M
  • Hidden Gem.
    1920 x 1080 - 4M
  • Yes, absolutely right. It looks fantastic, like a caldera where the fertile soil is in the remnant if the lava in the volcano's throat. The rest is just scoured to bedrock by the ejecta.
    Regards,
    Richard.
  • As far as the eye............
    2625 x 1477 - 6M
  • Where the pines grow.
    1920 x 1080 - 4M
    That's a lot of pines!
  • 100,000 pines scattered.
    edited December 2025
    That is a lot. I can remember a time when 200 facets was a lot for a computer to cope with (doing finite element analysis with 200 elements (facets) and about 250 nodes (vertices). That was hard work for a 640k RAM 286 PC with a 20Mb HDD. Yes the HDD was 20Mb, I haven't written it wrong.). Ahh. How times change.
    Regards,
    Richard
  • Wow. Crazy how much times have changed.
  • Hello, I'm not sure if it's the best place to ask it, because my question is relative to UltraScatterPro (https://www.daz3d.com/ultrascatterpro--upgrade-from-ultrascatter-advanced-instancing), not UltraScatter 2, but I didn't found a topic for UltraScatterPro, and I guess the answer should be the same for UtraScatter 2...
    I created a Christmas garland by loaded a cylinder and a plan in the scene, and then, I used the UltraScatterPro to position several instances of the plan along the cylinder:
    Since a garland can have several "positions", I created some morph to the cylinder, in order to give it a true garland aspect; however, the instances of the plan don't follow automatically the surface of the cylinder:
    To fix it, I have to recreate the instances every time I apply a garland morph...
    Of course, it's not a big deal, but I wonder if there wouldn't exist a better way, to make the instaces following the cylinder's surface automatically, rather having to recreate them everytime I apply a new morph. Could you help me, please?
    Thank you in advance!
  • The Wild Outback.
    3072 x 1728 - 8M
  • Signs of life.
    1920 x 1080 - 3M
  • That looks perfect. The low sun is a brilliant effect. Regards, Richard.
  • Thank you.
