CMS Path in IM - how to change
AndySAndyS Posts: 1,447
Hi,
I have to install DAZ on my new PC.
Now I want to set the correct paths.
Why isn't it possible to set an own new cms-path? IM ever changes it back to "C:/Users/andre/AppData/Roaming/DAZ 3D/cms"
In the field "Content Database Base" I select my own new path "E:/Daten/DAZ 3D7cms". Then I press "Accept".
After returning to the advanced settings the entry again is "C:/Users/andre/AppData/Roaming/DAZ 3D/cms".
Why ??
Regards
Andrew
Post edited by AndyS on
  • Richard HaseltineRichard Haseltine Posts: 107,911
    Try setting it in DS - Edit>Preferences>CMS Settings.
  • AndySAndyS Posts: 1,447
    Hi Richard,
    nice suggestion.
    But I'm not at this step jet (installing DS).
    If DS is installed with the "wrong" cms-paths, it already established all database information. So after changing the paths at this late state, I have to manually move all cms files from %appdata% to the wanted location.
    One important remark:
    For security reasons:
    All user data are not allowed to be stored on the system drive. Never!
    And the cms database is User data.
    I know, Microsoft does the same fault.sad ( ->Standard install path for user programs)
    So please don't use %appdata% as the primary/default location.
    Thank you
    Andrew.
    I found a solution:
    First I copied the database files from my old PC to the data HDD location of my new PC.
    In the cmscfg.json I edited the "DatabaseClusterPath" directing it to the %appdata% location.
    In the %appdata% location I redirected it to the cms location on my data HDD.
    This way it worked.
    But it is a bad workaround.
    Regards
    Andrew
    At one time DIM seemed to be less relaible for changing the (shared) ContentCluster path, that was why I suggested trying DS.
