Can't Log In To Daz Studio
roninwolf109roninwolf109 Posts: 64
I have no idea what's going on here, but I can't log into Daz Studio. I ran a program to get rid of all the mulitiple files on my hard drive and now I get the pop up in the attachement below when I try to log in.
I've already tried uninstalling and reinstalling Daz Studio. What can I do here?
Thanks!
Post edited by roninwolf109 on
  • That has nothing to do with logging in to your account, it is wanting to communicate with PostgreSQL which it does using Internet Protocol on the local system. It sounds as if the utility deletd that which it should not have deleted - I would think a first step worl do to uninstall and reinstall PostgreSQL
  • How do I do that?
  • ElorElor Posts: 3,339
    If you're using DIM, I would search for 'PostgreSQL' and 'PostgreSQL CMS' will likely be the only result.
    If you did a manual installation, you should be able to get the installer here: https://www.daz3d.com/downloader/customer/files#prod_18869
  • If you installed through Install Manager thne find it in the Installed tab and click the Uninstall button, then find the same version in the ready To Download/Ready to Install tab (depending on whether or not you kept the package) and click the Download/Instal button.
  • IceCrMnIceCrMn Posts: 2,324
    You also need a Connect folder mapped in the Content Manager even if you don't use it.
    If the program deletes empty folders then it may have deleted the Connect folder if it were empty.
    With Studio running press F2 and on the bottom of the Content tab click the "Content Directory Manager" button and look to make sure "Daz Connect Data" is pointing to a folder that exists.
    If the folder isn't there or the entry is blank then you can simply make a new one by clicking on "Daz Connect Data" and on the left side of the pane the word "Addd" will light up.
    Click that and navigate to the location of your new Connect folder.
    1015 x 926 - 262K
  • Okay, I've tried uninstalling and reinstalling PostgreSQL a few times and I'm still getting the same popup when I try to run Daz.
    Here's what I see when I go into the Content Director Manager. It looks like I've got a folder there, or at least it takes me to a folder when I right click the Edit Base Directory.
    576 x 565 - 98K
    edited October 2025
    That appears to be on onedrive
    Keep that in mind because online storage of those files can be a headache.
    I had the same problem you have so I moved mine to a different location and stopped using onedrive becasue of all the problems with file syncing and all that stuff.
    I'm on Win11 Pro so I also disabled onedrive.
    I never liked it and never used it, it was causing me nothing but problems.
    Post edited by IceCrMn on
  • It worked fine until I ran the program to delete a bunch of double files on my hard drive. Apparently something got deleted that shouldn't have been now I get the popup in the original post.
  • If you go to Edit>Preferences, then click the CMS Settings tab - are there entries in the text boxes?
  • I've got it fixed. Spent all day having to reinstall all my assets and, hopefully, my saved files weren't corrupted...
    Thanks for the help, everyone!
