How to bake daz3d material to PBR?
How to bake daz3d material to PBR, so I can use it on other software.
  • What do you mean? The Iray shaders are PBR.
  • JamesJames Posts: 1,178
    Like for example the cornea. It doesn't use pbr. So in twinmotion, it get's changed to somehting else.
  • felisfelis Posts: 6,081
    edited October 2025
    Which character is that?
    I think most (all?) recent characters use Iray Uber, if not using PBR Skin.
    Post edited by felis on
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,485
    use clear glass in Twinmotion
  • Richard HaseltineRichard Haseltine Posts: 109,151
    edited October 2025
    All of the base Iray shaders are PBR, PBRSkin is a specific PBR shader designed for handling skin - non skin materials may well not use it. The Cornea probably won't work with PBRSkin, but if you want to try then select the figure and the surface and apply the PBRSkin shader preset.
    what about eyelashes
    just add the cutout opacity texture to the masking channel, it's just a standard material
