How to bake daz3d material to PBR?
James
How to bake daz3d material to PBR, so I can use it on other software.
James
What do you mean? The Iray shaders are PBR.
Like for example the cornea. It doesn't use pbr. So in twinmotion, it get's changed to somehting else.
Which character is that?
I think most (all?) recent characters use Iray Uber, if not using PBR Skin.
use clear glass in Twinmotion
All of the base Iray shaders are PBR, PBRSkin is a specific PBR shader designed for handling skin - non skin materials may well not use it. The Cornea probably won't work with PBRSkin, but if you want to try then select the figure and the surface and apply the PBRSkin shader preset.
what about eyelashes
just add the cutout opacity texture to the masking channel, it's just a standard material
