[Solved] Everyday 2 Shirt for G8M is blocking bones selection, how to solve it?
ElorElor Posts: 3,326
Hello
I'm speaking about this product:
https://www.daz3d.com/everyday-2-for-genesis-8-males
I'm trying to set a scene and when I wanted to select Michael 8.1 Left collar bone, to apply a pose on it and the left arm, the Everyday 2 shirt prevented me from selecting and having the cursor hovering over any part of the shirt will instead select Michael 8.1's hip bone as show on this screenshot (sorry, MacOS doesn't include the mouse cursor in screenshot, but it's around yellow tooltip, hovering over the left collar in both cases):
If I hide the shirt, I can then select the left collar as intended:
As far as I know, it's not the normal behavior for clothes (I checked, the G8F version doesn't exhibit the same behavior), but I have no idea how to fix it (outside of filing a ticket, but I'd like to be sure the problem is at least seen by other users), so if anyone knows how to solve it, I'm all ears :)
Post edited by Elor on
  • crosswindcrosswind Posts: 9,637
    edited September 2025
    The issue comes from a wrong setup of Selection Group in Joint Editor.
    Select Hip bone under the shirt, with Joint Editor, in Tool Settings pane, set Selection Group to None. The issue will be gone.
    2560 x 1392 - 702K
    Post edited by crosswind on
  • ElorElor Posts: 3,326
    Thank you :)
