adding textures to shaders that dont have a texture option
is there some way to add a dropdown to an existing shader that does not have an option to select a surface texture. Is there a specific way of doing this? and no, parameter is not hidden in the surface properties.
  • Richard HaseltineRichard Haseltine Posts: 108,114
    That would require a new shader, or editing the shader if it was built in Shader Mixer.
  • crosswindcrosswind Posts: 9,576
    Not 100% sure what you want but is it the case that: a slot in Surfaces pane which was mappable but now you see no dropdown that you can choose to select a texture map for it ?
  • StratDragonStratDragon Posts: 3,273
    Richard, is there a tutorial that is up-to-date on this process you might be able to recomend on this?
    Crosswind. Yes a dropdown, and I've checked the hidden parameters to see if they might have been turned off, they're just no there.
    edited September 20
    1) Defining a slot that is originally non-mappable to be Mappable in Shader Mixer ; and 2) Resetting a non-Mappable slot to be Mappable so as to bring its Dropdown back are totally different things.
    So, you better name which Slot ? If the slot's Mappable attribute was set as false in the DUF file for some reason, you would not be able to see the Dropdown for assigning a texture map...
    Check this post to see how to fix it, if you have the above case 2). https://www.daz3d.com/forums/discussion/comment/8335231/#Comment_8335231
    Post edited by crosswind on
