Let's appreciate/discuss today's new releases - more ongoinger thread
1474850525369
  • SilverGirlSilverGirl Posts: 2,965
    doubledeviant said:
    @SilverGirl - You might be able to connect the plugs from Everyday Cables with the cords from RSA's dForce Strings and String Lights to get something close to what you're looking for?
    Oh hey, there's an idea! I even have that one and totally forgot about it. Thank you! I'll have to give that a go. I'll report back when I do!
  • davesodaveso Posts: 7,829
    Powerage has cables at rendo
  • tsroemitsroemi Posts: 3,488
    Now this I find really annoying. Why is there no base masculine version for the golden ticket by Luthbellina? Here: https://www.daz3d.com/psikodelia-bodysuit-hd-outfit-for-genesis-9. There's absolutely no reason I can see why this should be a female-only garment. Stuff is often not so easily fitted to the other gender on G9 as one might think. Why do so few vendors actually use the great opportunity G9 offers, and instead create dozens of morphs for the female characters only?
    I've noticed before that Luthbellina's stuff often only lists the feminine morphs on the product page, but once you look at the file list (which we can't do with this one because DAZ hasn't added it yet) then there are morphs for male characters too.  For instance, her Killer Bodysuit HD Outfit only lists feminine morphs on the page, but once you open the file list you can see morphs for Michael, Lawrence, Nathan etc. I don't know if there isn't enough room on the page to list all character fits any more or if it's just her choice, but she doesn't usually miss out the male characters.
  • joannajoanna Posts: 2,263
    Sadly, I have no need for it at all, but I still have to appreciate the amount of creativity that went into designing Ansiko's Wobble Corner, including all the small details and fun, consistent branding of the Wobble franchize ;).
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,163
    edited September 15
    I wishlisted it because I might want it one day but no rush, filling it with zombies could be a challenge
    no, billboards are no use, I do videos
    Unreal Engine allows me to use instances in different points on a looped animation so somewhat useful
  • caravellecaravelle Posts: 2,658
    + 10!!!
  • LeanaLeana Posts: 12,782
    "Veggie option: remove the meat yourself" laugh
  • Pax AsteriaePax Asteriae Posts: 457
    edited September 15
    It fits the guys nicely, but some might struggle with the footwear it comes with. (And he'd have preferred it if the straps came in black or brown.)
    On a related note, it's nice to see footwear with actual *wear* on the soles.
    1080 x 1080 - 503K
    Post edited by Pax Asteriae on
  • MissLeahMissLeah Posts: 210
    heart Very nice, Pax Asteriae! You've just convinced me to buy that bodysuit today. I have a boy who can use it. I really like how it looks with both the boots and the heels! laugh
    Thank you for the info and the cool render! I wasn't aware of this with Luthbellina. Will happily put the suit into the cart now yes
  • https://www.daz3d.com/wobbles-corner
    I purchased and installed Wobble's Corner, but only the web links were included.
    Naturally, I can't use the assets. I tried installing it manually, but it didn't work.
    Is anyone else having the same problem?
  • crosswindcrosswind Posts: 9,592
    https://www.daz3d.com/forums/discussion/743116/wobble-s-corner-product-problem
    You have to fill a support ticket.
  • Thank you for telling me,I'll try.
  • TimbalesTimbales Posts: 2,423
    Thank you to SIlverMoon for supporting men's clothing and including G8/8.1M fits with new content: https://www.daz3d.com/svms-rider-outfit-for-genesis-9-81-and-8-male ;
    I bought this immediately for the versatility.
  • barbultbarbult Posts: 26,261
    Link correction https://www.daz3d.com/svms-rider-outfit-for-genesis-9-81-and-8-male
  • FrankTheTankFrankTheTank Posts: 1,499
    I never thought I would see Moonman at Daz, lol.
  • ArtiniArtini Posts: 10,324
    edited September 18
    It is pretty easy to change the color of the straps in: https://www.daz3d.com/psikodelia-bodysuit-hd-outfit-for-genesis-9
    1920 x 1080 - 419K
    Post edited by Artini on
    Heck with the rest of the outfit... I want https://www.daz3d.com/x-fashion-wool-and-wild-outfit-for-genesis-9-and-8-81-female just for the tiger bunny hat!
  • LorraineLorraine Posts: 889
    edited September 21
    https://www.daz3d.com/tin-summer-radiant-beach-outfit-for-genesis-9-and-genesis-8-female
    Not today's outfit but bought on the 19th and installed and tested today and nearly returned for a refund. The skirt is unusable. It's not dforce, won't fit properly when figure is posed even when smoothing applied and amped. I tried dforcing it using Matew's scripts and all it did was jam up DS till I forced close, twice. So I deleted it from runtime and data. The only reason I didn't return the product was there was a bikini, bag, jandals, earrings and a waist chain in the outfit and they fit ok. I did change the bag to parent to the left hand instead of shoulder and made a morph to move the handles together.
    Post edited by Lorraine on
  • felisfelis Posts: 5,819
    edited September 21
    Crappy forum. I wrote a long text and then it just cleared it when posted.
    I don't have it.
    My guess is it is the belt and knot that is causing problems.
    If it has its own surface zone set Dynamic Strength to 0.
    If not add a dForce weightmap node. Select all and set weight to 0. And then select all the skirt below the belt, and set that to 1. And then smooth.
    Another method is to set self collision to off, but that means it can pass through itself and might not be desired.
    Post edited by felis on
    edited September 21
    I don't have it.
    Thank you, Felis, I'm willing to give it another go after reading that. But tomorrow. If I reinstall it and try again tonight and it fails I may just burst my boiler ;)
    And yes, very crappy forum...I'm trying to remember to copy everything I write before I push the post button.
    The Obliterated set today (https://www.daz3d.com/obliterated) looks well-made in many ways, but it's still one of those that always make me chuckle a bit. These bricks laying around are basically brand new, or rather, brand new bricks that have been left lying around for ages so their texture discolored. But they have never ever been part of a wall! There's no mortar attached - no pieces chipped - no corners, edges broken off ... etc. pp. Living in an old brick building that needs a lot of assistance myself, sets like this are the epitome of uncanny valley for me: so realistic yet completely unreal wink
    On another note, I love Sickleyield's ghosty set! https://www.daz3d.com/sy-dforce-sheet-ghost-genesis-9 . As always, it's so well thought out and gives many options, and it's also just darn cute and perfectly timed.
    What you call a ...erm...clean break.  It looks good from a distance, but up close, a hard pass.
    https://www.daz3d.com/dforce-su-loose-shirt-for-genesis-9
    Nice shirt, too bad there isn't a men's version
    It has a dedicated morph for G9 Masculine ...
    2560 x 1392 - 1M
    Perhaps Timbales means the buttons being on the wrong side for a man's shirt
    edited September 24
    Yes. The buttons and placket are reversed on men's clothing. And the extra folds of fabric on the male morph look odd to me.
    Post edited by Timbales on
    Ah... got it. If so, a man style can be easily added to the shirt with a morph plus flipped Bump and NM maps.
    2560 x 1392 - 2M
    It's always nicer for customers when the vendor does that ONCE instead of every interested customer having to do it individually. Many customers won't have the skill to do that. If a masculine morph is included in a shirt product, it seems like a masculine button placement is reasonable to expect. Don't you think?
